"Web images only" error
Thread begun 10/27/2009 6:39 pm by jebnetx86016 | Last modified 10/29/2009 11:07 am by Jason Byrnes | 3004 views | 3 replies |
jebnetx86016
When I select the check box "Web images only" and save the page and try to load it I get the following error
"Fatal error: Call to undefined function imagecreatefromjpeg() in E:\Webs\WebDev\PictureCat\WA_DigitalFilePro\HelperPHP.php on line 844"
If I don't check the box, then the page and script work
Thank you
This is an error you will get if the GD Library is not enable on your PHP server.
if it is a local server, open the php.ini file and find the following line:
;extension=php_gd2.dll
and change it to:
then restart the webserver. If it is a remote server, you will need to contact them to have the GD library enabled.
jebnetx86016
Yep, that was it – Thank you Jason
For those running IIS on Windows Server 2000 (IIS 5.0)
I have always used .ASP, but due to this new version of DFP and only supporting .PHP, I found myself having to research and install PHP on my local development server
The installation on Windows can be involved and confusion depending on which version of IIS is being used
Initially I just had downloaded the PHP zip file, and configured IIS to support the PHP ASAPI, but this very limited, and I was fortunate enough to find a tutorial explaining how to enable the php.ini referred above by Jason
Here is the link install_and_configure.php
Thank you
Jeb
Jeb,
thanks for sharing that link, I have not seen that one before, very helpful.
