File Uploaded but DB not
Thread begun 10/25/2009 11:18 am by Daryl | Last modified 10/26/2009 2:01 pm by Jason Byrnes | 4668 views | 10 replies |
DarylBeta Tester
I have added a DFP field to a DA page and have used the document that tells you how to combine the two.
The files are being uploaded, however the file name is not being inserted into the database despite me using the little thunderbolt as is shown in the document.
After doing this I am left with the following sort of entry....
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?>
Any ideas why its not working?
anonymous
Daryl,
That is the correct variable for your image name column... not sure what is going on there. Can you confirm that your insert statement or update statement comes after the DFP server behavior. I just want to rule out the possibility of the variable not getting set. Also, can you confirm that other columns are getting their respective inputs?
Best regards,
Brian
DarylBeta Tester
ah...
I had to move the insert behaviour above all other behaviours otherwise I got a Headers already sent error - there is a thread about this in the DFP area.
All other table columns are populated, however the file name ones are not.
PHP code is performed Top Down.
The Server File name Variable is created When the file uploads.
if the Upload File Behavior comes after the Insert Record behavior, then the Server File name will not have been created.
So moving the code may have alleviated the errors, but it did not fix the problem from your other thread.
lets move the insert record behavior back where it was and look into the cause of the error you where getting. can you send a copy of your k9_SaD_Insert.php page that is generating the error message so I can examine the code?
DarylBeta Tester
Server behaviour moved back and file attached.
The errors are;
  Warning: Invalid argument supplied for foreach() in .../WA_DigitalFilePro/HelperPHP.php on line 80
Warning: Cannot modify header information - headers already sent by (output started at .../WA_DigitalFilePro/HelperPHP.php:80) in .../admin/k9_SaD_Insert.php on line 157
anonymous
Daryl,
The Error about not being able to modify header information is 9 out of 10 times caused by white space above your Doctype Declaration and the HTML.
Many times, an inadvertent space added after a closing a PHP tag is the cause.
While it is ok to start new PHP blocks on a line down - you need to ensure there is zero chance of an actual space behind each closing PHP block.
You could even go as far as closing one and starting the very next one right after it like this: " ?><?php "
I would go through it - clean up any spaces and then try it again.
Regards,
Brian
Brian,
in this case the output to the page is the previous error:
since this is a warning, it does not stop the script from processing, so when it gets to the header function, the error is considered output and throws the header already sent error.
Daryl,
give me a few to look over the code...
DarylBeta Tester
No problem Jason
Daryl, there was some code out of order for the file upload.
I have rearranged the code in the attached copy of your file. Try this one.
DarylBeta Tester
Hi Jason
That did the trick.
Was it something that I did?
Just so that I know how to correct it in the future should it happen again.
