A couple of Errors
Thread begun 10/25/2009 7:30 am by Daryl | Last modified 10/25/2009 11:33 am by Office Guy-172461 | 5456 views | 6 replies |
DarylBeta Tester
A couple of Errors
I have been getting a few errors after updating DFP.
  Warning: Invalid argument supplied for foreach() in .../WA_DigitalFilePro/HelperPHP.php on line 316
  Warning: Cannot modify header information - headers already sent by (output started at ...WA_DigitalFilePro/HelperPHP.php:316) in .../k9_SaD_Insert.php on line 160
There are no blank spaces following any closing php tags and the form is set to multipart.
Any ideas?
Office Guy-172461
Solving the "headers already sent" problem
It's not just blank spaces. Have a look here:
148/
DarylBeta Tester
Thanks for the link to the knowledge base.
I have checked again for blank spaces or lines and there aren't any.
I have no idea what this means
  The solution is to eliminate anything that would generate any output that occurs before the call to header().
It appears to be the insert behaviour that calls the headers and there are three DFP behaviours before it.
Office Guy-172461
It means that the header() command must come before any html code that would generate any thing that's sent to the browser. The spaces are the most common because they are easily missed. If you make sure the header() command is on the first line, you should be able to avoid this error.
Office Guy-172461
I've updated the article with some more information. Let me know if it is still not clear and I will try to make it clearer.
DarylBeta Tester
I moved the insert behaviour above all of the others and this solved the error.
But now I have another problem - but I will make a new Topic
Thanks for your help!!
Office Guy-172461
You're welcome. Glad it worked for you.
