Problems getting repeating table to display
Thread began 10/23/2009 6:41 pm by roger391472 | Last modified 10/24/2009 7:00 am by roger391472 | 949 views | 2 replies |
roger391472
Hello,
I'm trying to display data using a repeating table and I'm having trouble with the formatting so I'm looking for some help to find what I'm doing wrong.
Here's what I've got: I've got a div on the page where I'm inserting the repeating table. I've tried numerous combinations of settings for the row and column values. I did get it to work a couple times but the content was either too close together or too spread apart. I'm trying to display 4 rows with 2 or 3 fields of dynamic data in each row. One would be an image and two would be text from the database columns. I found a thread that gave instructions to start the table out as one cell and then divide it in Dreamweaver so that's what I've been trying recently. I then put the dynamic binding in the top td and it displays the alternate styles fine and is laid out correctly with 4 rows, one on top of each other. I then apply the repeat region to the top td and instead of it displaying the records from top to bottom in each of the 4 td's it displays all 4 products horizontally across the top td. I also saw in a thread where the repeat region and repeat selection behaviors should automatically be applied when you insert the repeating table and that has happened but it doesn't all the time, sometimes I have to apply them afterwards.
What I really want is to display the product image on the left with the description text to the right of it. It would display 4 products at a time vertically, I.E one on top of the other.
Can anyone see where I'm going wrong here?
Thanks,
Roger
anonymous
Roger,
You need to make sure your repeat region happens around the table row with the dynamic data - not the table div.
So, your code should look like this:
<table>
      <tr>
         <td>Image:</td>
        <td>Descripton</td>
      <tr>
<?php do { ?>
       <tr>
           <td><img  src="images/<?php echo rs_row['image']; ?>" /></td>
           <td><?php echo rs_row['descr']; ?></td>
        </tr>
<?php } while (condition is met?>
</table>
Make sure you are only looping the table row with dynamic data as shown above.
Best regards,
Brian
roger391472
Solved
Hi Brian,
That did it.
Thanks,
Roger
