Error Creating BSM Database MySQL
Thread begun 10/23/2009 4:47 pm by gregurke385889 | Last modified 10/26/2009 11:58 am by Eric Mittman | 2248 views | 2 replies |
gregurke385889
Page 13 of the eCart Tutorial "To create the sample MySQL database"
The explanation for mac asks to use terminal. Tried it to the letter numerous times, didn't work. I am using MAMP now and have only just recently finished the PHP starter kit so am new to all this dynamic stuff (static web/graphic designer)
Anyway with MAMP running the MySQL Server I can go into MySQL admin and try and create the database form there right?
I copied the blue_sky_music.sql file to the Documents folder as directed, and went to create new database/schema but it gave me an error message. I then tried "restoring" the .sql file instead. I have attached (picture 1 ) to show the error message I keep getting after trying a number of times. (tried turning MAMP off, have run a diagnostic to repair permissions on the HD you name it.)
With MAMP I tried using MySQL Lite to create the db and it seemed to work although it won't sow up in MySQL Admin so I can follow the steps to add the table content.
Sorry if any of the above shows I have no idea, but I just want to push on.
Help!
DG
Office Guy-172461
I'm at a disadvantage here because I don't do Mac or MAMP but:
1. The .sql file is what's called a SQL dump file. It is just a text file full of SQL instructions that you can view in a text editor. It works the same as if you typed them in by hand.
2. You can run those instructions to create the database for you by importing or "run a batch file" depending on what program you are using (Not that you would want to).
Have a look here:
Exporting and Importing a database using phpMyAdmin
150/
phpMyAdmin comes pre-installed with most hosts.
One way that I create db's from backups like this is to create the db myself from either the command line or a GUI tool. Then when I have this empty db opened I just cut and paste the sql from the file into a query window and execute all the statements. It is probably worth getting phpMyAdmin installed if you are having a hard time with your current GUI tool. Another good tool for the Mac is sequel pro.
