Downloads help files not loading
Thread begun 10/19/2009 1:47 pm by Gavin Killackey | Last modified 10/20/2009 9:26 am by Jason Byrnes | 4156 views | 6 replies |
Gavin Killackey
I need to download the PDF files for this extension especially the how to "Changing PowerStore's Payment Gateway with eCart (PDF)"
Iam in Australia so the way it is set up is no good and I need to change the way it works as it will not process payments.
The link on the following page is broken powerstore/
Is there any other way to access this file?
We have had some reports of difficulty downloading PDF documents, mostly when Acrobat professional is installed.
To work around the problem, try right clicking the PDF link and selecting the Save Link As option to save it to your computer before opening it.
Gavin Killackey
Unable to Download PDF
Thankyou for the prompt reply however I have tried that and also tried it on another computer that does not have Acrobat Professional installed and can still not download it could you send me the file?
Gavin Killackey
Downloading Files
I managed to download it on a laptop But I also have another question I also need to remove the shipping is there a walkthrough for that.
In the WA_Globals.php file, leave the $WAGLOBAL_Shipping_Enabled set to false:
$WAGLOBAL_Shipping_Enabled = false
if you do not wish to use shipping.
Gavin Killackey
Hi Jason
I have one more problem and I cannot find the answer in the forum when product has been added to the cart and you try to confirm the order I always get a checkout failure.
I have only found one other reference to this on the forums but no answer.
I have used powerstore 1 succesfully but powerstore 2 is more confusing. Could you help ?
To troubleshoot, If you are testing using Express Checkout, add the following to the pp_checkout_failure.php page:
if(!session_id()) session_start();
echo(
"Auth request: ".isset($_SESSION['ECO_Auth_Request'])?$_SESSION['ECO_Auth_Request']:""."<br /><br />");
echo(
"Auth Result: ".isset($_SESSION['"ECO_Auth_Result'])?$_SESSION['ECO_Auth_Result']:""."<br /><br />");
echo(
"Get Request: ".isset($_SESSION['ECO_Get_Request'])?$_SESSION['ECO_Get_Request']:""."<br /><br />");
echo(
"Get Result: ".isset($_SESSION['ECO_Get_Result'])?$_SESSION['"ECO_Get_Result']:""."<br /><br />");
echo(
"Preocess request: ".isset($_SESSION['"ECO_Process_Request'])?$_SESSION['ECO_Process_Request']:""."<br /><br />");
echo(
"Process Result: ".isset($_SESSION['ECO_Process_Result'])?$_SESSION['ECO_Process_Result']:""."<br /><br />");
If you are filling in the checkout form on the checkout page, add the following to the checkout_failure.php page:
echo(
"PayPal Full Request :<br />");
echo(
"<code>".isset($_SESSION["PP_DirectPayment_postedValues"])?$_SESSION["PP_DirectPayment_postedValues"]:""."</code><br /><br />");
echo(
"Paypal Full Response :<br />");
echo(
"<code>".isset($_SESSION["PP_DirectPayment"])?$_SESSION["PP_DirectPayment"]:""."</code><br /><br />");
echo(
"USPS Full Request :<br />");
echo(
"<code>".isset($_SESSION["WA_Store_Cart_USPS_FullRequest"])?$_SESSION["WA_Store_Cart_USPS_FullRequest"]:""."</code><br /><br />");
echo(
"USPS Full Response :<br />");
echo(
"<code>".isset($_SESSION["WA_Store_Cart_USPS_FullResponse"])?$_SESSION["WA_Store_Cart_USPS_FullResponse"]:""."</code><br /><br />");
This will write the request that is sent to paypal as well as the response that is returned to the screen so we can get an idea of what is going wrong.
NOTE: The request will contain you api information, you should remove that portion when posting it on the forum.
