unable to create the table i need
Thread begun 10/16/2009 11:58 am by terry211640 | Last modified 11/14/2009 2:26 am by jhongavin393738 | 4655 views | 5 replies |
terry211640
hi to all
i am looking to create a table such as the link below
DG_177026
as you can see this is a landscape version which i am aware that this software - after getting the subscription- does not support
i am hoping that someone who is clever may be able to let me know how to create something like this.
ultimately the landscape colums do nothing other than provide information, what i need to change is the boxes on the right side. i would like to be able to enter a figure(hopefully dynamically) whcih will recognise if between two numbers and would insert into the relevant row with the number applied
does anyone know if this is possible
thanks for reading
terry
The type of chart that you are referencing on the page is not a type that the Dynamic Web Charts tool will create for you. It will create line, bar, pie and area charts. The area charts are like line charts but just filled in.
terry211640
thanks for your reply
although as i previously stated i was aware that this is not a type of chart supported, i was hoping some one could suggest how it could be created or even if it could seeing as it can not generated automatically.
i thought maybe i could create a table which housed the static landscape colour blocks but somehow then create adjoining blocks in a corresponding colour which i could dynamically add a number to and allow that block to be positioned along side the correct part of the table( based on if its between a certain range of numbers it goes here or if not it goes there)
if you can help it would be appreciated
perhaps if its not suitable in this section perhaps you could tell which part of this forum it would be better suited
cheers
terry
The type of chart you are looking to create is not available from Dynamic Web Charts, I'm not sure if you can create a custom chart like you are asking. If it were possible it would be a custom endeavor and would not be supported. You may want to ask around on the job board to see if someone there is up to the challenge or has a better custom solution for you to work with.
terry211640
thanks for your help
jhongavin393738
Hi
Thanks for both of them.
I have the same problem, I searched for this. finally I got here
