E Cart Activation every time I open site
Thread begun 10/15/2009 12:07 pm by georgina_barrett_187762 | Last modified 11/02/2009 3:37 pm by Eric Mittman | 2136 views | 3 replies |
Every time I open dreamweaver and use the ecart whether it is a current ecart I am editing or a new one it asks me to activate ecart.
Also when I try and add to cart button using the wizard - when I click look up item ID from recordset, I get this error:
While executing onClick in WAeCart AddToCart.htm, a Javascript error occured.
Then it wont let me select an ID column.
I have tried deleing the cart and creating a new one - but still I get the error.
I have opened a ticket for you on these issues so we can look into them further. For the repeat activation this problem can occur if you have a dynamic or changing MAC address on your machine. I have posted some steps you can take to record these values to determine if this is the problem for your activation.
As for the other issue with the cart this sounds like an issue that should be fixed in the latest release of eCart 4.5.2 at the time of this post. To update your ticket please login and visit your support history.
mail239361
I am also experiencing the same problem. I run Dreamweaver in a virtual machine (Parallels) on a MacBook Pro.
I will download the latest version as suggested but if there is further information around the activation issue it would be good to get that sorted.
If you are running this in a virtual machine it may be part of the reason you are having problems with this. Do you know if the active connection that you are using has a MAC or Physical Address that is changing when you start your virtual machine? If so then this type of repeat activation may occur for you. Please see the steps on this post here to record these values to see if this is what is happening for you.
showpost.php?p=15940&postcount=2
