Recordset Variables gone on install of DA
Thread begun 10/14/2009 8:13 pm by kdavid379212 | Last modified 10/16/2009 12:10 pm by Eric Mittman | 2834 views | 4 replies |
kdavid379212
Hello,
I have an interesting issue. Let me start by saying I purchased & am extremely excited about the Extension package since I've been happily using your products for a while.
I do have one strange and possibly serious issue upon installation, however. I closed ALL Adobe products and simulatiously installed DataAssist, Universal Email and Dynamic Form Elements through the Adobe Extension Manager (CS3). On each installation, I was given a warning that an old file (the same file each time) would be overwritten. Naturally I clicked to overwrite the old file. Whether or not that has contributed to this issue I have no idea, but now all my recordsets in any site fail to show the WHERE variables.
In more specific terms, previous recordsets in Dreamweaver CS3 would say something like SELECT * WHERE Site = colname. If you looked at the colname variable it would have a classic PHP value like $_GET['site']. Now the recordset on any previous file shows the variable missing. In other words, I still get the "SELECT * WHERE Site = colname" and the colname values are all there including the default "-1", but the "$_GET['site']" is absent.
So here's the troubleshooting steps to help you out:
1: Everything was working perfectly until I intalled the 3 products mentioned above.
2: I rebooted my computer and it did not help.
3: This is specific to THIS Dreamweaver / WebAssist installation for the following reasons:
a: Uploading files via F12 from Dreamweaver work fine on an actual production site in some cases for reasons unkown at this time, but work in other instances.
b: Viewing files in NotePlus++ show that the variables are actually there. It's as if the new Web Assist files are somehow set to read-only or some other restricting permission.
c: Opening the files on another computer in Dreamweaver CS3 that doesn't have Web Assist shows the recordset fine.
Hopefully these steps will provide you with an idea of what is going on. If you wish, I can install another Web Assist application and give you the exact file I mentioned above. Please feel free to contact me if you have any questions. Thanks for your help.
Sincerely,
K
kakadong
it seems I have the same problem like you....
Let's wait and see how they solve this ..
Would it be possible to post back and include some jpg screen shots of what you are seeing in your recordsets after you install the extensions, if you could include a second screen shot of the correct view of this from the other computer that would be most helpful.
Also, what is the version of DataAssist that you currently have installed and when you mention the Dynamic Form Elements did you mean CSS Form Builder or Dynamic Dropdowns? Please let us know what versions of these others you have installed also.
kdavid379212
Hello,
Thanks for the quick reply. I've included 4 images that should give you an idea of what I'm talking about. As far as the versions, I really am not sure how to tell other than they are likely the very latest ones unless a change has been made in the past 24 hours. The reason I'm saying that is because I only purchased the annual subscription yesterday morning and downloaded the versions roughtly this time (5PM CDT Octover 14, 2009) yesterday.
I am a little less "freaked out" as I now know that this is an annoyance rather than something that truly screwed up my files. In other words, the problem is local to the Dreamweaver installation as can be seen in the images. Uploading files to a web server works normally as the recordset variables are still there. They just cannot be seen by the Dreamweaver installation that had the WA products installed on it. If you open the files in Dreamweaver on another machine they appear normal (ie they lack the ! next to the recordset).
As mentioned before, this leads me to think that whatever file(s) or settings were changed or overwritten during the install of the WA program(s) has somehow disabled Dreamweaver from seeing recordset variables that are actually there.
I should also point out that seems entirely limited to the variables used to narrow queries in the WHERE clause of the recordset and does not discriminate based on $_SESSION, $_GET, $_POST, etc. Any variables that I have hand-coded in the PHP and / or not in recordsets show up fine in the Dreamweaver code view. Strange.
Anyhow, hopefully that gives you a better understanding of what is happening, please feel free to ask for more information,
Sincerely,
Kent
I have gone ahead and opened up a ticket for you on this issue. The ticket will probably be updated with a request for some more info from you to help us work this out. To check the status of the ticket or update it please login and visit your support history.
