Irite not updating XML styles
Thread begun 10/14/2009 6:02 am by dave315749 | Last modified 10/14/2009 3:48 pm by Jason Byrnes | 1794 views | 1 replies |
dave315749
I am trying to update the xml styles that are defaulted within fckeditor on the fckstyles.xml file. I am adding a center image style. But it does not show up on the editor when i upload the file. what else should i be editing and uploading for the editor to see the center style when clicked on a picture? currently my code is
<!-- Object Styles -->
<Style name="Image on Left" element="img">
<Attribute name="style" value="padding: 5px; margin-right: 5px" />
<Attribute name="border" value="0" />
<Attribute name="align" value="left" />
</Style>
<Style name="Image Centered" element="img">
<Attribute name="style" value="padding: 5px; margin-left: 5px" />
<Attribute name="align" value="center" />
</Style>
<Style name="Image on Right" element="img">
<Attribute name="align" value="right" />
</Style>
Rather then edit the xml file, add then to the iRite instance.
Create a css style sheet that contains the styles you wish to use, then edit the iRIte instance.
On the Styling tab, select the CSS style sheet you created, in the list of available styles, select each of the styles you wish to include in the list, then click OK and upload the WA_iRite folder
