2 Promo Code Fields
Thread begun 10/13/2009 8:30 am by sam308940 | Last modified 10/13/2009 7:14 pm by sam308940 | 3520 views | 6 replies |
sam308940
2 Promo Code Fields
I have 1 promo code field that operates like normal promo code fields do. This is on the view cart page.
I have a 2nd one promocode field, that is for wholesale customers. They enter a wholesale code and get a discount.
The wholesale discount is supposed to be off the total.
ie if the subtotal is $100. and the promocode gives 10% off, the new subtotal would be $90.
so when a wholeslae customer enters thier code to get 30% off, i need it to be based on the $90 not the $100.
currently its giving a discount off the $100.
how do i change this?
You can probably set up your second promo-code as a "charge" with a negative value... that way you can check the "apply after discounts" checkbox to make it work on the adjusted value.
sam308940
Hi Ray
so i would just enter the times -.30 to make a negative value?
but where is that apply after discounts checkbox?
im looking at the charges window and i dont see this.
sam
It only appears in the charges window when you use "based on cart subtotal"... and I think you may need the "0" in front of the decimal, so it would be:
times: -0.3
times: -0.3
sam308940
OK i did that. however - its not displaying anything for it.
i removed the item from discounts.
then i added a charge with all the same rules, based on subtotal, apply after discounts, and i tried -.3 and -0.3
it just simply seems to ignore it.
the only rules it has is
discountcode == pccw15
or
discountcode == PCCW15
I had a items > 0 in there, but removed it to test.
that didnt seem to change a thing.
any more ideas?
sam308940
ok it did work. scratch my earlier email.
however i had to change the code for the charges to display on the page.
if ($pcccart->RuleLooperValue("Charges") > 0)
had to change this line to:
if ($pcccart->RuleLooperValue("Charges") <> 0)
THANKS
