Unable to use eCart In Dreamweaver CS4 Mac Version
Thread begun 10/12/2009 8:42 pm by eaddudley390229 | Last modified 10/13/2009 3:28 pm by Eric Mittman | 1752 views | 1 replies |
eaddudley390229
I've downloaded the eCart extension for a Mac Dreamweaver CS4, then I brought up the adobe extension manager and install the eCart extensions. When I opened Dreamweaver and click on eCart to start a new shopping cart, I get the following error and eCart Activation window comes up but it's graded out not allowing me to enter serial number.
While executing onLoad in WA eCart Ser.htm, the following JavaScript error(s) occrred:
At line 214 of file "disk:Applications:Adobe Dreamweaver CS4:Configuration:Shared:WebAssist:eCart:Library:Shared_Ser_Mactivation.js": document.formLayer.document has no properties
What do I do? Has anybody founded answer to this error.
By the way, I've already deleted MacFileCache-EEEE2300.dat, and I've already renamed the configuration folders to ( configuration_back) so that dreamweaver could crated the folder again. and I've erased the extensions and installed them again.
Deleting the cache file then removing the configuration folder are the correct steps you should be taking, if they are not resolving the issue though there may be another problem. I have submitted a ticket for you on this issue so that it can be looked into more closely. To check the status of the ticket or update it please login to the site and visit your support history.
