All other data are visible in email except list data
Thread begun 10/11/2009 3:17 pm by chris384639 | Last modified 10/13/2009 11:13 am by Jason Byrnes | 2143 views | 2 replies |
chris384639
Hi. I'm having an issue with my UM data.
See the screen shot of my email.
jenkolaka19379118
Hi Chris,
I haven't looked at your zip files but if you are using static list options you MUST make sure the value is set to the options you want. e.g.
<select>
<option value="Monday">Monday</option>
<option value="Tuesday">Tuesday</option>
</select>
Universal Email passes the value to the email when you bind the form elements to the body of your email. So just check that you have the <option value=""> set to what you would like to display.
The values of a multiple select list will passed as an Array, you can use the PHP implode() function to convert the Array to a comma separated list.
in the WA_UniversalEmail/WAUE_index_1.php file, change line 94:
$MailBody = $MailBody .  ((isset($_POST["Appointment_request_group_Best_times[]"]))?$_POST["Appointment_request_group_Best_times[]"]:"");
$MailBody = $MailBody .  ((isset($_POST["Appointment_request_group_Best_times"]))?implode(", ", $_POST["Appointment_request_group_Best_times"]):"");
