Removing Ecart 4.5.1 extentsion
Thread begun 10/09/2009 5:20 pm by InDesigns Studio | Last modified 10/09/2009 6:19 pm by Jason Byrnes | 2948 views | 4 replies |
InDesigns Studio
Hopefully someone in this forum can help me with removing Ecart 4.5.1 so I can upgrade to eCart 4.5.2. Currently having problems removing it. I am getting this error when removing it from the extension manager.
The file AppData\Roaming\Adobe\Dreamweaver9\configuration\Shared\Webassist\eCart\Languages\Du\ButtonImages\Pacifica\Btn1_Du_wishlist.gif is being used by Dreamweaver CS3. Please close Dreamweaver CS3 and try again.
I am getting different erros every time I retry to remove the extension. I can't understand why I am getting this error when Dreamweaver is not even open.
Please help.
Appreciate anyone's quick response
Jaydee Escobedo
832-314-0266
email: houstonbusinesslisting@gmail.com
close Dreamweaver and the Extension manager, then try deleting the AppData\Roaming\Adobe\Dreamweaver9\configuration\S hared\Webassist\eCart folder.
after deleting that folder, try uninstalling again using the extension manager.
InDesigns Studio
Removing eCart 4.5.1 Extension
That simple! I guess if I have a similar problem in the future with removing an extension, just delete the folder.
Appreciate it.
Jaydee Escobedo
InDesigns Studio
Removing Ecart 4.5.1 Extension
Allright I have removed it and installed the new Ecart 4.5.2 with success but now I am getting an error when I open Dreamweaver CS3.
The error is
The following translators were not loaded due to erros:
WA_Forms.htm has a configuration informations that is invalid.
Any idea what I did wrong.
Appreciate your help on this.
Jaydee Escobedo
Go to Window -> Workspace Layouts -> Reset '<Layout name>'
If that does not fix the problem, something has been corrupted in the configuration folder, Go to:
rename the configuration, then reinstall the extensions.
