verify account setup by UE
Thread begun 10/08/2009 1:46 pm by JBWebWorks | Last modified 11/12/2009 12:01 pm by carlene | 7453 views | 8 replies |
JBWebWorks
Looking for PHP code to use UE to send auto email to verify a registration of account.
I know how to set up a registration form and how to get UE to send auto email to email address filled in the registration form.
Want to know what link to send with the auto email that a person clicks on to verify their account; and how clicking on that link performs the validation.
thanks
Jim Balthrop
tom92909Beta Tester
I did that very thing recently. This will require some hand coding maybe, but you should be able to do all if it with DataAssist, Security Assist & Universal Email.
I made the email address the unique account identifier.
I require at least an email address and a password.
In MySQL I have a user table that looks like this...
CREATE TABLE IF NOT EXISTS `users` (
  `UserID` int(11) NOT NULL auto_increment,
  `UserName` varchar(50) default NULL,
  `UserPassword` varchar(50) default NULL,
  `UserEmail` varchar(100) default NULL,
  `UserDate` datetime default NULL,
  `FirstName` varchar(50) default NULL,
  `LastName` varchar(50) default NULL,
  `UserIsAdmin` tinyint(1) default NULL,
  `BillingName` varchar(50) default NULL,
  `BillingAddress1` varchar(50) default NULL,
  `BillingAddress2` varchar(50) default NULL,
  `BillingCity` varchar(50) default NULL,
  `BillingState` varchar(50) default NULL,
  `BillingZip` varchar(50) default NULL,
  `BillingPhone` varchar(14) default NULL,
  `UserValidated` char(1) NOT NULL default 'N',
  `UserSessionID` varchar(255) default NULL,
  `UserIPAddress` varchar(30) default NULL,
  PRIMARY KEY  (`UserID`),
  UNIQUE KEY `UserEmail` (`UserEmail`);
My registration process only initially populates the UserEmail, Password, UserDate, UserSessionID, UserIPAddress fields. The `UserValidated` has a default value of 'N'. Later in the process that value will change to 'Y' if the user follows the process to completion.
1. Create your standard registration.php, login.php, profile.php, logout.php, forgotpassword.php files using the Security Assist wizard. You'll also want a duplicate_account.php file.
2. The Registration page checks the email address for duplication, if found it redirects to the duplicate page. If not found it inserts a new account in the user table, and using Universal Email sends a welcome message to the new user that has a link embedded in the body of the message. This link includes a SESSION_ID....
Example:
validate_user.php?id=42599f0b88578b93c4d2a935bd2e4bfd
3. You will have to create some informational pages to explain the process to your guest users.
4. You will need to create a validate_user.php file that compares the link and the users current session ID and what was written to the user table moments ago. If they match, then you validate (change the 'N' to a 'Y') if not don't validate and redirect to a new page that explains the failure.
The above is a quick summary of the process. I offer this with the hopes that it will point you in the right direction, but there are probably other ways of doing this, but this is a way that I have found to accomplish the task.
JBWebWorks
thanks Tom
i have been working on this and have a question about how the UserIPaddress field is used and how to implement?
i am sure i will have other questions as i get this to work for me.
Jim Balthrop
The UserIP address is not really 100% necasarry, it is optional info.
To capture it when the user registers, in the insert record server behavior, Select the UserIP Column, click the Lightning bolt next to value and select the REMOTE_ADDR variable from the server collection in the bindings panel.
JBWebWorks
thanks Jason
i probably won't use the UserIP
one question in using WA cookies toolkit
in setting the session value, what goes in the value field?;
and if that produces a random session string, how do i get it in the insert record field to identify the user when later validating?
thanks again
go to the bindings panel.
Click the Plus button and select SecurityAssist -> Random Password.
Then in the set session value server behavior, click the lightning bolt next to value, and select the random password binding.
To store the random string in the DB, use the DataAssist insert record server behavior.
Select the random string column, and bind it to the random string session variable.
JBWebWorks
thanks again Jason
works perfectly.
you're welcome.
carleneBeta Tester
This is amazing!
Thank you all for posting this great solution!!
I'm going to try it.
