PHP Errors
Thread begun 10/06/2009 6:32 pm by pipwax1204510 | Last modified 10/16/2009 7:15 am by Office Guy-172461 | 12819 views | 18 replies |
pipwax1204510
PHP Errors
This is my error. ===========Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/p/i/p/pipwax2/html/test/login.php:14) in /home/content/p/i/p/pipwax2/html/test/login.php on line 48
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/p/i/p/pipwax2/html/test/login.php:14) in /home/content/p/i/p/pipwax2/html/test/login.php on line 48============
I am following the web application recipes instructions. However, when I make an attempt to code in the Cookie - object Code Snippet I get this error. Is there an Errata for this book.
isbn 0735713200
Dani Chankhour
The error that you are getting indicates that you have a space or something that is being outputted to the page before a session_start call.
Please look at line 14 or 48 and remove any white space that you see between the php tags.
pipwax1390564
PHP Error
Originally Said By: Dani Chankhour
Thanks! I will try that.
pipwax1390564
Php error
Worked like a charm!
pipwax1390564
More PHP Errors
Can anyone tell me what this error means
=============================Begin error=============================
Parse error: syntax error, unexpected ':' in /home/content/p/i/p/pipwax2/html/test/send_password.php on line 46
============================end Error=================================
Dani Chankhour
Could you paste line 46 of send_password.php?
pipwax1390564
More PHP Errors
Here is line 46
======================Code-====================
$from = “From: webmaster@sk8photos.com <webmaster@sk8photos.com>\r\n”;
=====================end Code============================
John LangerBeta Tester
Originally Said By: pipwax1390564
  Here is line 46
Just while you're waiting for a real expert on PHP to get back to you (at PHP coding I'm a novice) the error code is saying that it doesn't like the colon in "From:" Try using the ascii code for a colon instead "&#58;" (without the speech marks).
If I had this situation, that's what I would try. Hope it helps.
pipwax1390564
PHP Errors
I changed the code to this:
$from = &#8220;From':'webmaster@sk8photos.com <webmaster@sk8photos.com>\r\n&#8221;;
Now I am getting this:
Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING in /home/content/p/i/p/pipwax2/html/test/send_password.php on line 46
Sorry, the forum substituted the ascii code for the actual colon. Hopefully this will show ok. Replace the colon with & # 5 8 ; I've put a space between each character to stop it showing as a colon. use those 5 characters but without the spaces.
Hope that makes sense.
