CSS Sculptor error!
Thread began 10/01/2009 9:26 pm by info345621 | Last modified 10/02/2009 1:32 pm by swbgraphix | 2844 views | 3 replies |
info345621
CSS Sculptor error!
Error:
While executing onLoad in wacs_wizard.htm, the following JavaScript error(s) occurred:
In file"wacs_wizard":
InitializeUI is not defined
mark.hay302689
Same problem - resolved
I had exactly the same issue this morning - Only change made recently was upgrade of data assist
I cleared the winfilecache
your user folder \AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration
And all now seems to work - Hope that helps
Yes, deleting the Dreamweaver cache file from the users configuration folder should resolve the issue:
swbgraphix
Error Fixed
Yes Jason, deleting the maccache file worked perfectly. Thx.
