Digital File Pro V1 - Delete File
Thread begun 10/01/2009 9:33 am by karen.marley367377 | Last modified 10/23/2009 3:52 am by karen.marley367377 | 3026 views | 2 replies |
karen.marley367377
Update pages have Digital File Pro Upload functions, with hidden fields to hold original files, if the user chooses not to update them.
I would like to add the Digi File Pro Delete Function for situations where the user no longer requires the image.
Have tried adding another button and using the Delete function, but can't get this work.
Have also tried applying this to a separate page, with a simply form the recordset in question, and the delete file function on "submit" button, but still cannot get this to work.
Any ideas?
On the delete page add a hidden form element, set the initial value to the File column from the recordset.
Then apply the delete record server behavior. Set the delete folder to the relative path to the upload folder. Click the Lightning bolt next to Delete File and select the hidden form element.
karen.marley367377
Thanks!
Thank you Jason, much appreciated as always!
