Cannot Load iRite Form
Thread begun 9/26/2009 9:21 pm by wintoons156288 | Last modified 9/27/2009 7:30 pm by wintoons156288 | 2832 views | 2 replies |
wintoons156288
Hi there,
I need help here.
I have inserted the irite on my form page. When I have finished creating it and do a test on it, the form page wont come up because it is saying this error message :
Warning: require_once(C:\xampp\htdocs\wintoonsMain\forum\WA_iRite/fckeditor.php) [function.require-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\wintoonsMain\forum\WA_iRite\WARichEditorPHP.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'C:\xampp\htdocs\wintoonsMain\forum\WA_iRite/fckeditor.php' (include_path='.;C:\xampp\php\pear\') in C:\xampp\htdocs\wintoonsMain\forum\WA_iRite\WARichEditorPHP.php on line 1
As you can see, the problem is that the fckeditor.php page seems to be missing but the WARichEditorPHP.php page is there. It seems that it doesn't create it.
What do I do here?
Wintoons
anonymous
Under the warning, I noticed it is mixing path types - some of it appears to be windows absolute and some of it appears to be relative to document.
I would bet this is an issue with your testing server attributes in your Dreamweaver site definitions not being set correctly. Can you share your settings here and we can take a look...
In my experience, the iRite include always pulls relative to the document.
Best regards,
Brian
wintoons156288
I figured it out
Thanks for the tip.
Now I know what happened. You see, I have my website on a testing server in my network and I only made an FTP connection (without doing any Site Definition) and all it was doing was just creating one file in the WA_irite folder. But the rest weren't created at all. <:|
So anyway, I made a Site Definition to connect to my Testing server and I only have to manually put the files from my local folder (on my Mac) to my testing server and now all the files are there. And I did a test and it works fine.
Strange.
Wintoons
