images upload but filename not moving into db
Thread begun 9/23/2009 8:14 am by iain.sutherland290832 | Last modified 9/23/2009 10:24 am by iain.sutherland290832 | 4957 views | 6 replies |
having an issue. always worked in the past with v1, but in v2, now getting an issue where all the form fields are carried into the db, except for the file names. I have used the WA behaviors to set the server file name but they are not being carried into the DB
the link to the test page for this function is:
itemimages_Insert.php?ItemID=12
have i missed something?
code on top of page is:
<?php require_once("../Connections/mayther.php"); ?>
$ItemID = $_GET[ItemID];
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "images/thumbs/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "1",
'ResizeWidth' => "100",
'ResizeHeight' => "100",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1_2 Start
$WA_UploadResult1_Params["WA_UploadResult1_2"] = array(
'UploadFolder' => "images/imagesmedium/",
'ResizeWidth' => "300",
'ResizeHeight' => "300",
// WA_UploadResult1_2 End
// WA_UploadResult1_3 Start
$WA_UploadResult1_Params["WA_UploadResult1_3"] = array(
'UploadFolder' => "images/largeimages/",
'ResizeWidth' => "629",
'ResizeHeight' => "473",
// WA_UploadResult1_3 End
// WA_UploadResult1_4 Start
$WA_UploadResult1_Params["WA_UploadResult1_4"] = array(
'UploadFolder' => "images/originalitems/",
'ResizeWidth' => "800",
'ResizeHeight' => "600",
// WA_UploadResult1_4 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "FileName", "2", "[NewFileName]_[Increment]", "JPG:80", $WA_UploadResult1_Params);
$itemid = $_GET[ItemID]; ?>
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $mayther;
$WA_table = "itemimages";
$WA_sessionName = "WADA_Insert_itemimages";
$WA_redirectURL = "itemimages_Results.php";
$WA_keepQueryString = false;
$WA_indexField = "imageID";
$WA_fieldNamesStr = "ItemID|imagesmall|imagemed|imagelarge|imagedescription";
$WA_fieldValuesStr = "".((isset($_POST["ItemID"]))?$_POST["ItemID"]:"") ."" . "|" . "".((isset($_POST["imagesmall"]))?$_POST["imagesmall"]:"") ."" . "|" . "".((isset($_POST["imagemed"]))?$_POST["imagemed"]:"") ."" . "|" . "".((isset($_POST["imagelarge"]))?$_POST["imagelarge"]:"") ."" . "|" . "".((isset($_POST["imagedescription"]))?$_POST["imagedescription"]:"") ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_mayther;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
tom92909Beta Tester
Did you upload the new version of the Digital File Pro extension to your web server?
yep - re posted
tried that,
tried changing file types and conversions options
tried changing filename
moved image folder to a higher level in case it was a ../ issue
now also getting more errors (as the page has been re-edited so many times)
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/sites/mayther.co.uk/public_html/WA_DigitalFilePro/HelperPHP.php:4) in /home/sites/mayther.co.uk/public_html/WA_DigitalFilePro/HelperPHP.php on line 73
Warning: Cannot modify header information - headers already sent by (output started at /home/sites/mayther.co.uk/public_html/WA_DigitalFilePro/HelperPHP.php:4) in /home/sites/mayther.co.uk/public_html/admin/itemimages_Insert.php on line 85
i may have to start a fresh page
tom92909Beta Tester
Have you tried stripping out the entire behavior from your page, verifying that you only have the form on your page, saving your page and then starting over?
yep
tried that here addanimage.php?ItemID=12 but get exactly the same issue
In the Insert record server behavior, you are binding the Image columns to the file Form elements.
Digital File Pro Creates a new data binding group WA Uploaded Files (File Field Name)
In this group is a Server File Name variable. One is created for each upload location, for example:
images/thumbs/[FileName]: Server File Name
images/imagesmedium/[FileName]: Server File Name
In the insert record server behavior, you should bind the image columns to the Server File Name Varibles created by DFP.
See the How to apply Digital File Pro to DataAssist Insert and Update pages tutorial on the DataAssist support page in the How To section:
dataassist/
hmmm ... That was where I started the process, but it did not carry the filenames to the db so I tried every other permutation I could think of. will try it again. the page has been through about 10 hours of different versions.
and guess what - it worked - i must have been having a mad moment this morning - thanks for assistance
