cURL unable to post
Thread begun 1/04/2022 9:42 am by Jamie | Last modified 1/04/2022 3:27 pm by Ray Borduin | 3974 views | 9 replies |
Jamie
cURL unable to post
Hi Ray
Trying to install a new CMS and the activation is failing saying that cUrl is unable to post to the webassist server https://gyazo.com/91773d6c83addc9643bd490df166df5b
Have set up a test page here https://dev.motley.co.uk/testCurl.php
Jamie
You can use:
curl_setopt($cHandler, CURLOPT_SSL_VERIFYHOST, false);
curl_setopt($cHandler, CURLOPT_SSL_VERIFYPEER, false);
Then it won't be as strict with the ssl check causing it to fail.
Jamie
Ok thanks have done that https://dev.motley.co.uk/testCurl.php
the setup diagnostic is still failing
Can I get FTP access and a link to the cms install? I'll debug and see what I can find.
Jamie
thanks...here you go
It should be working now. I'm not sure why it was reporting the ssl mismatch, but I added:
to the installation test.
Jamie
thanks Ray - got through that but now cant activate with the serial number. Have 'put' files up 3 times now,....
https://gyazo.com/2c7ff2c5623a666fb67dfb801bf75047
Does your hosting admin have an option:
“Pause Cloudflare on Site”
It looks like Cloudflare is interfering with curl. This is something that your hosting provider might be able to help with.
When I request webassist's site with curl it returns:
html:
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<meta name="robots" content="noindex, nofollow">
<title>One moment, please...</title>
<style>
body {
background: #F6F7F8;
color: #303131;
font-family: sans-serif;
margin-top: 45vh;
text-align: center;
</style>
</head>
<body>
<h1>Please wait while your request is being verified...</h1>
<form id="wsidchk-form" style="display:none;" action="/z0f76a1d14fd21a8fb5fd0d03e0fdc3d3cedae52f" method="get">
<input type="hidden" id="wsidchk" name="wsidchk"/>
</form>
<script>
(function(){
var west=+((+!+[]+!![]+!![])+(+!+[]+!![]+!![]+!![]+[])+(+!+[]+!![]+!![]+!![]+!![]+!![])+(+!+[]+!![]+!![]+[])+(+![])+(+!+[]+!![]+!![]+[])+(+!+[]+!![]+!![]+!![]+!![]+!![]+!![]+!![])),
east=+((+!+[]+!![]+!![]+!![])+(+![]+[])+(+!+[]+!![]+!![]+!![]+!![]+!![]+!![]+!![])+(+!+[]+!![]+!![]+!![]+!![]+!![]+[])+(+!+[]+!![]+!![]+!![]+!![]+!![]+!![])+(+!+[]+!![]+!![]+!![]+[])+(+![])),
x=function(){try{return !!window.addEventListener;}catch(e){return !!0;} },
y=function(y,z){x() ? document.addEventListener("DOMContentLoaded",y,z) : document.attachEvent("onreadystatechange",y);};
y(function(){
document.getElementById('wsidchk').value = west + east;
document.getElementById('wsidchk-form').submit();
}, false);
</script>
</body>
</html>
I did some google searches on that message an dpage and it appears to be related to cloudflare, but I'm not 100% sure. One way or another it is using some sort of intermediate to verify the site and that is causing it to fail.
Jamie
Weird. The hosting Co don't use cloudflare nor have I 'installed' - they have checked their logs within the window when I tried and you replied and they cannot see any blocks on external connections
Not really sure where I go from here?
Call me on Skype and I'll help you get through it.
