Form for contact not working
Thread begun 12/06/2021 10:18 am by jhood-fysh78990 | Last modified 12/09/2021 9:49 am by Ray Borduin | 2082 views | 6 replies |
jhood-fysh78990Beta Tester
Hello,
I have a form on a webpage that is not working now. When I run a test results php script, the comments field always returns a failure. Originally, it was a required field, so I edited the code to remove the required status thinking that would fix the submission error but it did not.
I have attached the page as a private message
thank you
Delete line 14 to remove the server validation on the Comments field.
Hi Ray,
Thank you for the quick response.
I tried what you suggested and still got the error. Here is what I get when I run the Test submission script.
Who is your hosting provider? Is john@wwmore.com a valid email address? Can I get FTP access and a url to test? I'll see if I can debug and figure out what is wrong.
Thanks for the response ray. I have included the information you requested.
It looks like your server is configured to not send emails if they aren't FROM a valid email address registered on that domain.
You will have to use one of the @archercaptioning.com email addresses as the FROM address listed here: https://us.cloudlogin.co/mail/
When I did that on a test page it was able to send.
Thanks Ray,
I will make that change.
