WADYN_MYSQLI_CONN htm
Thread begun 11/11/2021 11:18 am by Ericspecullaas | Last modified 11/14/2021 9:48 am by Ray Borduin | 1311 views | 3 replies |
Ericspecullaas
Im using dreamweaver CC 2021 and getting this message when ever I use webassist menu. This message will not go away I have cleared over 100 and it still pops up. I did see in the config folder there was a connections folder and in there a php_mysql folder with 2 folders 1 for mac and 1 for win. Im not sure witch one is causing the error. I do have XAMPP v3.3.0 running when attempting to use the program.
You probably just need to delete your winfilecache .dat file from your local user's configuration folder for dreamweaver.
1) Shut down dreamweaver
2) Go to %appdata%/Adobe/Dreamweaver 2021/en_US/Configuration
3) Delete the file named WinFileCache-xxxxx.dat
4) Restart Dreamweaver and the error should no longer occur
Ericspecullaas
I figured it out. What happened is when I added Data Bridge v2, Design Extender V1, MwSQLi Server Behaviors and eCart v6 all at the same time it causes a conflict. Im not sure if it a Dreamweaver 21.2 thing or what. But the conflict causes dreamweaver to basically lock up and makes all webassist plugins unusable. So for now Im running with just the MySQLi Server Behaviors one because its the most stable one and allows me to actually open up your dialog boxes.
It is probably a conflict with Design Extender.... Just install DataBridge last and I think everything would be ok.
