Insert Plug-in to Div
Thread begun 5/11/2021 6:06 am by birdscreen398247 | Last modified 5/11/2021 2:01 pm by Ray Borduin | 806 views | 3 replies |
birdscreen398247
In the tutorial for Dynamic Dropdowns for DataBridge V2.
At Step 2 of “Add HTML to Main Page” it says to “Place your cursor after the closing </form> tag.”, but the screen shot shows that line BEFORE the closing </form> tag.
Which is correct?
When I did Step 1 of “Integrate Child Page and Add Ajax Functionality”, it deleted the <div id="childSelect"></div> line
And the “<?php echo((isset($WA_childselect_1620736350539))?$WA_childselect_1620736350539->Body:"") ?> line has a red ! In the Behaviors Menu
In Step 2 of “Integrate Child Page and Add Ajax Functionality”, I don’t get the option for “Load Plugin to Div.”
My only choices are “Insert Plug-in” and “Insert Dynamic Plug-in”, neither of which matches the menu in the tutorial.
I think it should be before the </form> tag since you want the second list inside of the form.
In Step 2, make sure you are looking in the "Behaviors" panel. It sounds like you are looking at the "Server Behaviors" panel, which has different options.
birdscreen398247
I found the Insert Plug-in to Div.
Now, as soon as I select an entry in the parent dropdown list, I get
"Not Found
The requested URL was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
By any chance do you have the finished tutorial files main.php and childSelect.php so I could compare with mine and figure out what is different?
Did you upload all of the /webassist/framework folder? If you give me a url to test then I could help debug. If you give me FTP access then I could fix issues I find. The only tutorial I have is the online one you are looking at.
