Users getting a 404 page when trying to login
Thread begun 5/06/2021 3:33 am by Mags | Last modified 5/07/2021 9:05 am by Ray Borduin | 2520 views | 5 replies |
Mags
Hi Ray, some users on one of our clients' sites are having problems logging in and are reporting getting the 404 page. It's only affecting some users and seems to happen particularly if they click on a link in an email which goes to a protected page on the site, but has also been reported by some users when they're on the site and click the login link there. The obvious explanation would be that it's a local issue since it doesn't happen to everyone, but the fact that it seems to be affecting quite a few people does make me wonder if there's some other explanation.
I asked the client to follow up with one particular user to get exact details of what was happening, and got the following response:
User received an email with a 'register here' hyperlink, which goes to a protected page on the site. Clicks the link, but is taken to the 404 page - he doesn't even get as far as the login page.
Browsers used: Microsoft edge but also tried Google Chrome and it is the same
Which email system are you using, and is this via your browser or do you have the email application on your computer? Microsoft Exchange
If you open your browser and copy and paste the link (don’t click on it) into your browser will it let you access the page? No
I asked him to try it in a private window and this worked (although I have had to reset his password for him)
He has since tried it again normally (without a private window) and it still won’t work
Do you have any ideas what's happening? I can give you links and FTP access.
I'd need to reproduce the issue. Can you send me the email with the link that goes to the 404 error? 404 means page not found, so it is something wrong with the link itself.
In order to fix any issue, you need to be able to reproduce it. Otherwise you wouldn't be able to test if you have fixed it even if you did try to do something. At this stage, when a problem is first reported, you need to work on doing whatever is necessary to reproduce the problem. If you follow the same steps as the user, then you should get the same result.
Once you can send me steps to reproduce, then I'll be able to get it resolved for you, but I really need to see it first to diagnose the cause and test to make sure I've fixed it.
Mags
That's the problem, I can't reproduce it. It works fine for me and also for our client, but random other users say it doesn't work. It does appear to be a cookie or cache problem because I've now heard that this particular user cleared their cookies and cache and it then worked for them. I've put the details in the PM section if you want to take a look and see if it works for you.
It might be something with their email client messing with the link. A 404 page means a bad link. I'd have to see the bad link to see what is wrong with it. This link seems to work, so maybe something is messing with the link before it gets clicked.
Do you have someone that can reproduce it that is willing to do a screen share to debug it? One way or another I'm going to have to see the problem to fix it.
Mags
I did suggest to my client that I could do a screenshare with someone so that I can see exactly what's going on, but no luck so far. It is all pointing to local issues though - so many people just don't know how to clear their cache and cookies for a particular site. I might actually put some instructions on the client's website on how to do this!
OK. If you get someone that can reproduce it, let me know and I'll do screen sharing to debug and fix the issue.
