Any changes to shipping connectors?
Thread begun 4/07/2021 10:58 am by Steve | Last modified 4/12/2021 1:41 pm by Ray Borduin | 3790 views | 15 replies |
Steve
We're getting the error:
Shipping Quote Failed
We're sorry
Could not connect to UPS
No recent changes or updates and the latest version of eCart6 so not sure why this is happening..?
Your UPS account may need to be updated. I know they require an active card on file. Log into your UPS account and make sure it is up to date.
If you var_dump() the $_SESSION after a failure you may get more information, but it sounds like an issue with your account at UPS.
Steve
Removed
Steve
I've created my own UPS account today and updated confirm.php to use the new info. Same error (Could not connect to UPS) :-(
I can connect directly to the URL (https://www.ups.com/ups.app/xml/Rate) from my location but not sure if the application is somehow being restricted.
This is an old site where we have run this cart for 12+ years and made no recent changes.
Steve
I have found success using this URL:
https://onlinetools.ups.com/ups.app/xml/Rate
IF this is the proper solution all users of the Cart will need to update their files. Please test and confirm.
Sorry I didn't even remember that it has been so long. We updated that in our code at least 8 years ago, so only people like you that have had sites working for a decade without updating would run into it. I'm glad you were able to find the solution on your own. I was going to suggest giving me FTP access and I would have made sure you had the latest version of the ups include file as a first step.
Steve
Ray, my original installation was version 5 of eCart. I have the latest version of eCart installed in DW2021
Question: What other significant changes occurred that may cause issues and does the latest version have provisions for auto-updating outdated files?
MySQLi updates would be necessary as well as PHP 7.* friendly code seems necessary.
You have to re-apply server behaviors individually for the code to update. MySQLi updates and pho7 updates are all included in the latest build. You should probably reinstall to make sure all of your files are up to date before starting your migration and save a backup of the site in case anything goes wrong.
I usually move a copy of the entire site into a /beta/ folder and make all of my changes there and test them before pushing everything live.
Steve
Thanks for the reply Ray, that's exactly what I am doing (duplicate site) for updating and testing prior to releasing live.
Steve
Ray, this one is not showing in the Server Behaviors so I'll need to manually recreate.
What is it actually doing? Inserting IF there is no record in the user table or updating a prior record based on the email address index?
$_SESSION['UserID'] = 0;
// WA eCart Store Cart Summary in Db
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $hearingImp;
$WA_table = "users";
$WA_redirectURL = "";
$WA_indexField = "UserEmail";
$WA_fieldNamesStr = "UserEmail|UserFirstName|UserLastName|UserCity|UserState|UserZip|UserIP|UserPhone|UserFax|UserCountry|UserAddress|UserAddress2";
$WA_fieldValuesStr = "".$_SESSION['eCartCheckoutForm_email'] ."" . "|" . "".$_SESSION['eCartCheckoutForm_firstname'] ."" . "|" . "".$_SESSION['eCartCheckoutForm_lastname'] ."" . "|" . "".$_SESSION['eCartCheckoutForm_city'] ."" . "|" . "".$_SESSION['eCartCheckoutForm_state_province'] ."" . "|" . "".$_SESSION['eCartCheckoutForm_postcode'] ."" . "|" . "".((isset($_SERVER["REMOTE_ADDR"]))?$_SERVER["REMOTE_ADDR"]:"") ."" . "|" . "".$_SESSION['eCartCheckoutForm_phone'] ."" . "|" . "".$_SESSION['eCartCheckoutForm_fax'] ."" . "|" . "".$_SESSION['eCartCheckoutForm_country'] ."" . "|" . "".$_SESSION['eCartCheckoutForm_street1'] ."" . "|" . "".$_SESSION['eCartCheckoutForm_street1'] ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_sessionName = "UserID";
$WA_Sql = "";
$NeedInsert = false;
$indexFieldIndex = -1;
$WA_connectionDB = $database_hearingImp;
$updateFieldValue = "";
if ($WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos('?', $WA_redirectURL) === false)?"?":"&").$_SERVER["QUERY_STRING"];
for ($i = 0; $i < sizeof($WA_fieldNames); $i++)
if ($WA_indexField == $WA_fieldNames[$i])
$indexFieldIndex = $i;
break;
$deleteFieldValue = "";
$updateColType = "none,none,NULL";
if ($indexFieldIndex >= 0) $updateFieldValue = $WA_fieldValues[$indexFieldIndex];
if ($indexFieldIndex >= 0) $updateColType = $WA_columns[$indexFieldIndex];
if ($updateFieldValue != "") {
$updateParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, $indexFieldIndex);
$valueForWhere = WA_generateInsertParams(array($WA_indexField), array($updateColType), array($updateFieldValue), -1);
$WA_Sql = "update " . $WA_table . " SET " . $updateParamsObj->WA_setValues . " where " . $WA_indexField . " = " . $valueForWhere->WA_dbValues;
$WA_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$result = mysql_query("SELECT * FROM " . $WA_table . " where " . $WA_indexField . " = " . $valueForWhere->WA_dbValues, $WA_connection);
$row = mysql_fetch_assoc($result);
$_SESSION[$WA_sessionName] = $row['UserID'];
$num_rows = mysql_num_rows($result);
$NeedInsert = (mysql_num_rows($result) === 0);
if ($updateFieldValue === "" || $NeedInsert) {
$insertParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "insert into " . $WA_table . " (" . $insertParamsObj->WA_tableValues . ") values (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
header("Location: ".$WA_redirectURL); exit;
