Thread begun 4/05/2021 6:47 am by FPhu61701534 | Last modified 4/08/2021 9:26 am by Ray Borduin | 1447 views | 3 replies |
FPhu61701534
Image uploader keeps appending .png each time an upload happens
I want to allow the user to update his profile photo and company logo. The newly uploaded files will be named after the existing files. For example, existing file = "Tommy201.png". The new updated file should also be saved in with the same name so that no matter how many times the user change the photo or logo, there is only one image of the same name in the folder. This is to save storage space.
Problem: Based on the settings in the attached screenshots, the images can be successfully uploaded but the uploader keeps appending the file extension with every update.
How do I prevent this from happening? What should the settings be? I don't want the filename to get longer with every new image upload.
Try using:
[php]
<?php echo(basename($Recordset1->getColumnVal("imgProfilePhoto"))); ?>
[php]
FPhu61701534
I added echo and basename per your advice...
'FileName' => "".echo(basename($Recordset1->getColumnVal("imgProfilePhoto"))) ."",
It can't work. Syntax error.
I tried adding basename this way instead...
'FileName' => "".(basename($Recordset1->getColumnVal("imgProfilePhoto"))) ."",
No syntax error. But I still face the problem of the .png appending with every file upload.echo
The second example is what I was referring to. The echo() is only needed when entering through the UI and not when editing the code directly.
I read up on this more and it appears basename() will not be as easy to use as substr()... try:
'FileName' => "".(substr($Recordset1->getColumnVal("imgProfilePhoto"), 0, strrpos($Recordset1->getColumnVal("imgProfilePhoto"), "."))) ."",
