premier support ticket error
Thread begun 3/25/2021 12:11 pm by Jonas | Last modified 3/27/2021 9:42 am by Ray Borduin | 2866 views | 10 replies |
Jonas
It is not possible to send a support ticket. There will be an error message. So I'm writing my message here.
You helped me with form validation that works with bootstrap, in the past. Unfortunately, I have not figured out how it works. I have tried countless forms. First by generating from WA form tool. And then add / change the html code to bootstrap. But there is always something wrong. It does not work like what you helped me with. Can you show me again? If so, do you want me to pay for this?
Do you have the old page that had it working? I don't remember how it was done, but if I look then I bet I'll be able to figure it out and explain what is on the page.
What error do you get when submitting the premier request form? I just tried and had no issues.
Jonas
I received a validation error message and the fields were cleared. Then I pressed the browser's back button and tried again. But got it wrong again.
I enclose the file that works "registrering.php". As well as the two files (the form and the thank you page) that I do not get to work.
Note that I have only entered validation on the first field to test. The result is that the error message is displayed in black and with the wrong class "serverInvalidState", instead of "invalid-feedback". I also attach screenshots of this.
I also notised an error from crome, see screenshoot.
The key is to add the setting to the jqvalidation code at the bottom:
orientation: "custom"
once you do that, it won't try to reposition the error message, but you have to add the id to the error message like:
<div id="**FIEKDNAME**_waerror_errorMsg_wrapper" class="invalid-feedback">Error message</div>
It looks like you didn't add the necessary ID to the error div on your page.
Jonas
I do not understand. Line 154 on bestallning.php contains this code. Example of the corresponding code on registration.php is on line 106 - and there it works.
Yeah that does look right... do you have the same version of: webassist/jq_validation/jquery.h5validate.js
is this on the same site? Do you have a url where I can view the page?
Jonas
This is not the same website. But I copied that file from the location where registration.php is located. So this should be the same, I think?
I worked locally with this, so unfortunately I can not give you any FTP information. But if you want, we can skype?
I found this on the web: https://formvalidation.io/guide/validators/greater-than/. It is an extended version of the validations included in Bootstrap. However, I have not tried it yet. But the best thing would have been if we could solve it so I can still use WebAssist validation.
The error implies that the javascript file wasn't found. Can you put it live somewhere? I'd have to charge you for a support ticket to do live screen sharing.
Jonas
I'm just wondering if I can not use WA's Jquery validation instead? But I do not know how to implement this. Is there any tutorial on this? In that case, I would, in the best case, only be able to delete the JS code at the end that Bootstrap requires and use WA's equivalent. Or am I thinking wrong?
It looks like you didn't do either of the two steps I outlined above:
Change the setting for the orientation to custom like:
I did that on your test page for the first field and it appears to work. You would have to just update the div id's for the others.
