My file manager is not working and upon investigation my kcfinder/filebrowse.js has errors
Thread begun 3/20/2021 10:35 am by jo271221 | Last modified 3/24/2021 12:25 pm by Ray Borduin | 1967 views | 5 replies |
jo271221
I am attaching a screen shot of what my browse window looks like and my filebrowse.js file.
I did resend all the kcfinder files to the server.
I am using mySQLi and on the most recent version of PHP.
URL, Log In Credentials and FTP are in private message
I found there was an issue when you rename your file field to not end with a number. I fixed the problem on your page and fixed it in DataBridge. If you reinstall it will work with renamed fields in future applications. For now all of the updated files are in your /webassist/kcfinder folder.
jo271221
Thank you.
When I click done from this page nothing happens, the image is not uploaded.
https://www.mysite.com/webassist/kcfinder/index.php?mode=pick&showsidebar=false&theme=webassist_v2
What browser are you using? I tried and it seems to work for me when I come from the update page and it opens the popup. I select an image and hit "done" and it returns to the page... Make sure you have cleared your browser cache, maybe one of the fixes I implemented isn't working because of cached files.
jo271221
Thank you.
It must have been the caching issue. Now I have another issue, the files are being uploaded to user-files and I want to ad the id of the logged in user to the file so it will be user-files/1 or whatever the user id is. Also when I browse I would expect to see only files from the directory 1 (user-files/1).
I did a find by user-files on my update page and I cannot seem to find where that is handled. I also opened up the server behaviors and I do not see it there.
Just create a session variable: $_SESSION['WA_UserUploadFolder'] (you can do it in the login server behavior)
Then it will use that folder automatically.
