Redirect problem after successful login and assign user level
Thread begun 1/07/2021 8:51 pm by Rokon | Last modified 1/12/2021 9:56 am by Ray Borduin | 2910 views | 5 replies |
Rokon
Hello
I am having problem with the login and redirect after successful login, I already edited the code to go to $SuccessRedirect = "../admin.php?loggedIn=1";
unfortunately after a first try it redirect to the redirected page but after logout when I try to login again it does not go the redirected page rather it stay on the login page.
Also pls help me how to assign the user level as I didn't find a complete guide on this.
The necessary information for the ftp is in the PM
What username and password are you using to log in? I'll need that to reproduce the problem.
Rokon
The detail in the PM, Sometime it works and sometime it does not work and shows like
https://www.hadithbd.com/user/login.php?accesscheck=%2Fadmin.php%3F%26accesscheck%3D%252Fadmin.php%253F
You are using the wrong access rule on the admin.php page. That access rule is for the login page to show a success message when you aren't redirecting to another page.
You should be using the MySQLi Restrict Access to page server behavior with the "authenticate" Authentication on the admin page. The FTP information you gave me doesn't seem to allow me to upload a page, but the code should look like this:
<?php require_once('webassist/mysqli/authentication.php'); ?>
if (true) {
$RestrictAccess = new WA_MySQLi_Auth();
$RestrictAccess->Action = "restrict";
$RestrictAccess->Name = "authenticate";
$RestricAccessRedirect = "user/login.php";
  if (
function_exists("rel2abs")) $RestricAccessRedirect = $RestricAccessRedirect?rel2abs($RestricAccessRedirect,dirname(__FILE__)):"";
$RestrictAccess->FailRedirect = $RestricAccessRedirect;
$RestrictAccess->execute();
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>Admin page - Secure page!</title>
</head>
<body>
    <h3>This is a secured page</h3>
    <h3><a href="user/logout.php">Logout</a></h3>
</body>
</html>
Rokon
This post has been deleted.
Rokon
if (true) {
  if (
<!doctype html>
<html>
<head>
</head>
<body>
</body>
</html>
Well noted. Thanks.
