Need some guidance on file uploads and project direction
Thread begun 10/30/2020 11:20 am by sjones435326 | Last modified 11/03/2020 8:52 am by Ray Borduin | 1234 views | 3 replies |
sjones435326
Hello, I need some guidance if anyone can point me in the right direction.
I am creating a CRM using DataBridge. I'm in the beginning stages planning out the schema. My biggest question is how to setup file uploads? I want to be able to have multiple files uploaded and associated with a contact. I have created an uploads table in the DB that would hold three columns
[id] [contact_id] [fileName]
When I upload a .pdf file for the contact, I want to store those three values in the uploads table using the contact_id as the key that connects the contacts table with the uploads table.
I would then like the details page to be able to return the query from the contacts table and also return the fileName from the uploads table that share the same contact id ( uploads:contact_id = contacts:id )
If anyone understands what I’m trying to achieve can you please point me in the right direction? Maybe include a link to a tutorial or give your input as to how you might handle this scenario.
I have included the DB file, it may shed some light on what I'm trying to do.
I don't really see any questions I could answer in your post. I think I understand what you are trying to do, and your strategy seems sound. I'd jump in and start working on it and then post back here when you have specific questions.
sjones435326
Hey Ray, is there a specific tutorial that shows how to do file uploads that would take the contact_id from the current contact which is displayed using the "contacts" table and when I upload a file for that contact, I want to store the file on the server and update the "uploads" table with the contact_id and the file name. If there is no tutorial, I can get myself to that point and then I will follow up this post with a more specific question regarding updating the recordset. If you know of a tutorial please supply the link or hang with me and I will reach out when I get to that point.
I don't know of a tutorial, but it should be pretty straightforward to help you if you run into any problems.
