Function using if isseet Post not getting or triggering function
Thread begun 10/28/2020 7:10 am by lr_leal239405 | Last modified 10/28/2020 2:59 pm by Ray Borduin | 2412 views | 5 replies |
lr_leal239405
Can you look at my fle attached starting from line #159. (copied below). I would like it to perform function of Insertirng based on if (isset($_POST["quote_record_exists_ID_".$z])) . It's not seeing my post "quote_record_template_exists_ID_<?php echo $z; ?>" from line 673.
You can see the whole function on (see info on private below)
if (isset($_POST["quote_record_exists_ID_".$z])) {
$qz = $_POST["quote_record_exists_ID_".$z];
//echo $qz;
//die();
$WADAquote_record_exists_ID = new WA_MySQLi_RS("WADAquote_record_exists_ID",$convacc_cx,1);
$WADAquote_record_exists_ID->setQuery("SELECT * FROM cac_quote_new_records WHERE quote_id = ? ");
$WADAquote_record_exists_ID->bindParam("i", "". $qz ."", "-1"); //Paramprod_id
$WADAquote_record_exists_ID->execute();
if ($WADAquote_record_exists_ID->TotalRows > 0) {
$opts = $WADAquote_record_exists_ID->getColumnVal("optionals");
$WADAquote_optionals = new WA_MySQLi_RS("WADAquote_optionals",$convacc_cx,0);
$WADAquote_optionals->setQuery("SELECT * FROM cac_quote_new_optionals WHERE quotenum = ? AND session_id = '$opts' ORDER BY optional_id ASC");
$WADAquote_optionals->bindParam("i", "". $WADAquote_record_exists_ID->getColumnVal("quotenum") ."", "-1"); //Paramprod_id
$WADAquote_optionals->execute();
if ($WADAquote_optionals->TotalRows > 0) {
$wa_startindex = 0;
while(!$WADAquote_optionals->atEnd()) {
$wa_startindex = $WADAquote_optionals->Index;
$InsertQuery2 = new WA_MySQLi_Query($convacc_cx);
$InsertQuery2->Action = "insert";
$InsertQuery2->Table = "cac_quote_new_optionals";
$InsertQuery2->bindColumn("quote_id_person", "s", "". $_SESSION['aq_ID'] ."", "WA_BLANK");
$InsertQuery2->bindColumn("session_ID", "s", "". $produniqid ."", "WA_BLANK");
$InsertQuery2->bindColumn("quotenum", "s", "". $quotenum ."", "WA_BLANK");
$InsertQuery2->bindColumn("quantity", "s", "". $WADAquote_optionals->getColumnVal("quantity") ."", "WA_BLANK");
$InsertQuery2->bindColumn("part_no", "s", "". $WADAquote_optionals->getColumnVal("part_no") ."", "WA_BLANK");
$InsertQuery2->bindColumn("prod_name", "s", "". $WADAquote_optionals->getColumnVal("prod_name") ."", "WA_BLANK");
$InsertQuery2->bindColumn("price", "d", "". $WADAquote_optionals->getColumnVal("price") ."", "WA_BLANK");
$InsertQuery2->bindColumn("totalprice", "d", "". $WADAquote_optionals->getColumnVal("total_price") ."", "WA_BLANK");
$InsertQuery2->bindColumn("DimensionsForShipping", "s", "". $WADAquote_optionals->getColumnVal("DimensionsForShipping") ."", "WA_BLANK");
$InsertQuery2->execute();
$WADAquote_optionals->moveNext();
$WADAquote_optionals->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
I think instead of:
if (isset($_POST["quote_record_template_exists_ID_".$z])) {
you want:
for ($z=0; isset($_POST["quote_record_template_exists_ID_".$z]); $z++) {
lr_leal239405
Thanks so much. It definitely goes in with that code. However, when the Search finds lots of results, and I add my 'Add to Autoquote' button, it inserts lots of Optionals instead of only the ones that belong to that quote (which is the intent). I don't know where my logic is flawed. Attached is the new file. (You'll see I added the code 2x for different posts).
you can do a search in this quote (below on private)
Press the 'Search All Products with Keywords' link. Search on empty and it yields all results. When you select any it will now insert Optionals repeatedly for any. And Some of those, like the first ones on the list are not even part of the $_POST.
Not sue what is flawed with my logic.
Thanks.
I'm afraid I don't understand your requirements enough to do this outside of a phone call with screen sharing. If you want to do that then give me a call or send me a skype message and we can schedule a time.
lr_leal239405
I tried calling. What time is good for you? I'll show you on the screen sharing
I'm here now for the next few hours if you want to try calling.
