Marking As "Tax Exempt"?
Thread begun 10/14/2020 5:33 am by yogastudents362523 | Last modified 10/14/2020 12:14 pm by Ray Borduin | 1628 views | 5 replies |
yogastudents362523
Hello,
I need to mark some of my gateway provider transactions (but ALL the transaction emerging from an eCart Object I have created specifiically for donations) as Tax Exempt. Simply marking items with a tax of zero is insufficient. Exempt is required.
I recently interacted with Authorize.net. My conversation with them pasted underneath.
I have used the search string "Tax Exempt" to search for WebAssist documents on this topic, and found nothing.
How do I use an eCart object to mark transactions as Tax Exempt so Authorize.net can put that on the official receipts they send out?
Additionally ... could you please tell me which lines in which file I would need to add in the PHP coding, because I have made quite a few styling and other amendments to some of my pages, and I do not want to have to start all over again, (i.e. if this is some setting I need to amend in the eCart object.
I am on the latest version of eCart 6.
Thank you,
KB
Authorize.net Chat Transcript follows:
11:45:55 UTC Jordan : To start, are all of your transactions donations?
11:46:31 UTC KB: No. Only some (my addendum: but once again, all the transactions in the eCart object that I use for Donations)
11:47:36 UTC Jordan : Is your website set up through a major website provider suck as WooCommerce or was it custom built?
11:47:54 UTC KB : Custom
11:48:54 UTC KB : They all have the Name ”KB Donation”
11:49:31 UTC Jordan : Regarding the option for marking transactions as taxable or not then, your web developer would need to add that option to be selected for "tax exempt" on transactions processed as donations.
11:51:02 UTC Jordan : Alternatively if your web developer is using the Authorize.Net provided payment form in your website you would need to make the following change:
-Click on the Account tab
-Click on the Payment Form link
-Click on the Form fields link
-Check the boxes in the View and Edit columns for "Tax Exempt"
-Click the Save button at the bottom of the page to save your changes
yogastudents362523
Hello,
I have seen the following lines on the xxxx_confirm.php page:
$AuthNet_itemized[0][$nextIndex] = "Taxable";
$AuthNet_itemized[1][$nextIndex] = "YES";
Would I need to do anything more than change that to a "NO"?
I have also found:
$AuthNet_optional[0][$nextIndex] = "x_tax_exempt";
$AuthNet_optional[1][$nextIndex] = "FALSE";
And would I need to do anything more than change that to a "TRUE"?
Should I change both, neither, or only one?
Any other parameters I need to take note of and alter?
Thank you,
KB
Yes. I believe that is all you would have to do.
Change both.
yogastudents362523
I will do so.
I also apologise for "updating" when you had posted a reply.
I just looked hard again, and saw the second value.
Thank you.
WIth every good wish,
KB
yogastudents362523
Hello,
I changed both values, and am now getting correct tax exempt receipts (TEST MODE) through authorize.net.
This is now also concluded.
Thank you,
KB
