multiple insert
Thread begun 8/19/2020 5:57 am by Sweens | Last modified 8/20/2020 3:39 pm by Ray Borduin | 1385 views | 4 replies |
Sweens
multiple insert
Hi Ray
Having problems with this - it never seems to work first time! I've played round with everything I can think of, but no joy. The form appears, you can select post, but when you press the button, nothing is added to the database.
Cheers
Chris
It looks like it should work. I'd need FTP access and a url to reproduce in order to debug this.
Sweens
Thanks Ray.
pm
The issue was that you had manually used a repeat region server behavior to repeat the <option> tags in your select list. That reset the repeat variables that are used in the multiple insert server behavior. You have to use the Dynamic Select list option from the Select list Properties panel to populate a select list from the recordset when using a multiple record server behavior.
I've updated the live page for your reference.
Sweens
Many thanks, Ray
Cheers
Chris
