Populate update page
Thread begun 8/04/2020 7:50 am by Jonas | Last modified 3/16/2021 2:15 pm by Ray Borduin | 3101 views | 14 replies |
Jonas
I have created a dynamic dropdown menu based on the tutorials: Dynamic Dropdown with Data Bridge 2.0 (http://www.webassist.com/tutorials/Dynamic-Dropdowns-with-Data-Bridge-2-0.
It consists of insert, update, detail and results pages. All pages except update work as they should.
In my case, the main menu is countries, and the child menu is cities.
On the update page, of course, I want to show the city that is registered together with the country. But this does not work. I have tried to figure out the problem, but get nowhere. The country is displayed correctly, but the menu of cities is empty. To see the associated cities, I must now first select another country from the country menu. Only then are the associated cities displayed. This is a problem. But I also want the one who is registered to first appear when the update page is displayed, just like country. Hope you understand what I mean.
Here is the select code for the city page (plugins), for the update page:
<select class="form-control" name="cities" id="cities">
<option value="0" <?php if (!(strcmp("", ($WADAbuckets_update->getColumnVal("buc_citID"))))) {echo "selected=\"selected\"";} ?>>Välj Ort</option>
while(!$rsCity->atEnd()) { //dyn select
<option value="<?php echo($rsCity->getColumnVal("cit_id")); ?>"<?php if (!(strcmp($rsCity->getColumnVal("cit_id"),($WADAbuckets_update->getColumnVal("buc_citID"))))) {echo "selected=\"selected\"";} ?>><?php echo($rsCity->getColumnVal("cit_name")); ?></option>
$rsCity->moveNext();
} //dyn select
$rsCity->moveFirst();
</select>
Does this look correct?
Please attach the update page so I can see the code. You probably just have to set the default before the initial plugin is loaded.
Jonas
Lets find out!
I don't see any references to the plugin on the update page: samling-uppdatera.php
Jonas
Lets try again!
I think you can just add this above the plugin code on the top of the page:
$_POST
['buc_couCode'] = $WADAbuckets_update->getColumnVal("buc_couCode");
Jonas
Fantastic, it worked. How did you come up with this? Where is the logic, hmm? Can be good to know.
Your cites plugin filters the recordset with the value: $_POST['buc_couCode']
So you have to make sure that value is set to the correct default when the page first loads.
Jonas
Hello again Ray!
Now I have update the content on both pages above, but I can't figure out why It does not work at this time. The problem now on the update page is that, then I choose another country - the content from the plugin page (citys) disappear from the page.
It show the corresponding city then the update page load, which is correct. But if I want to change country - the city disappear?
I don't even see a reference to the cities plugin on the update page. Did you attach the right page?
