date not saved correctly on update recordset
Thread begun 4/06/2020 12:28 am by Ashok | Last modified 4/09/2020 10:32 am by Ray Borduin | 2419 views | 7 replies |
Ashok
Hello,
I have 2 date form fields. On opening the update recordset page, date is shown as 04-30-2020 (from 2020-04-30 in db). If I do not change the date and update recordset, date changes to 1970-01-01 in db. This case is with both date feilds.
Php file attached.
Help appreciated.
Open your Update Record server behavior and go to the bindings tab and change the data type from text to date and that should fix the problem.
If you are displaying dates as m-d-y then you should be using m/d/y. PHP treats dashed date values as d-m-y.
Ashok
I recoded the page. Now I have issue with datepicker. If the date is say 2020-04-01 (y-m-d) and I click in the form field, datepicker popsup as April1 (1901) and not April2020.
Please refer screenshot.
Please attach the actual page you are working on. It looks like the datepicker is set to use m-d-Y not Y-m-d. That can be changed in the datepicker code if that is what you want to use. The code that has to be added in the javascript is:
dateFormat: "yy-mm-dd"
Ashok
Page attached.
This looks correct. Can I get a url to see the problem live?
Ashok
Sent in private. Ftp also required?
This page appears to be using a different style datepicker. I think it is using the bootstrap datepicker. Try using format instead of dateFormat in the creator function.
