eCart 6 Bindings Panel
Thread begun 3/30/2020 6:53 am by Ian Sheldon | Last modified 3/30/2020 10:27 am by Ray Borduin | 1315 views | 3 replies |
Ian Sheldon
It's been a while since I used eCart but using it to build a site right now.
Is there supposed to be anything in the Dreamweaver bindings panel relating to eCart? Such as column headers, totals etc? It's not showing anything.
Cheers
Ian
If you add any eCart functionality to the page then it should show up, so bindings will appear on add to cart pages or display pages.
If you are starting from nothing then you would have to manually add the eCart reference to the page to have the bindings appear. The necessary code is:
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
$eCart1
->GetContent();
// WA eCart Redirect
if ($eCart1->redirStr != "")     {
  if (
function_exists("rel2abs")) $eCart1->redirStr rel2abs($eCart1->redirStr,dirname(__FILE__));
header("Location: ".$eCart1->redirStr);
  die();
Ian Sheldon
Hi Ray!
Thanks for the reply.
Yup, I have those on the page but nothing in the bindings panel at all the relates to eCart.
I'm running Dreamweaver 20.1 on Mac OS.
//WA eCart Include
require_once('WA_eCart/infinityCart_PHP.php');
$infinityCart->GetContent();
if ($infinityCart->redirStr != "") {
if (function_exists("rel2abs")) $infinityCart->redirStr = rel2abs($infinityCart->redirStr,dirname(__FILE__));
header("Location: ".$infinityCart->redirStr);
die();
Edit ** No problem! I sussed it **. I had amended the include file to sit on one line to conform to the include code on the rest of the page. Thanks!
Does the eCart Object show in the Server Behaviors panel? Is eCart installed properly and you can open other eCart interfaces? I have the same dw version but I'm not on a mac.
If you continue to have issues please post your phone number in the private area of a reply and I can do screen sharing to see if I can find the problem.
