ecart ver 6.13 receive warnings in my error log using php 7.3.6 PHP
Thread begun 2/03/2020 11:46 am by RMor41509037 | Last modified 4/08/2021 9:22 am by Ray Borduin | 3107 views | 8 replies |
RMor41509037
Hi using ecart ver 6.13 and receive the warnings in my error log using php 7.3.6 everything works just posts these to error log
PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCart_Rule has a deprecated constructor in /home/raceprotim/public_html/WA_eCart/WA_eCart_Definition_PHP.php on line 4
PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCartDisplayCSSLooper has a deprecated constructor in /home/raceprotim/public_html/WA_eCart/WA_eCart_Definition_PHP.php on line 1000
PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WAPPECOPFProHTTPObject has a deprecated constructor in /home/raceprotim/public_html/WA_eCart/PP_ECO_Scripts/PP_ECO_PHP.php on line 1079
PHP Warning: number_format() expects parameter 1 to be float, string given in /home/raceprotim/public_html/WA_eCart/PP_ECO_Scripts/PP_ECO_PHP.php on line 74
These issues can probably be ignored. However I think they are fixed in the latest version. If you upgrade and install the latest version of eCart you can update it to fully support php 7 without errors.
RMor41509037
Hi Ray
Thanks for the reply. Is 6.13 not the latest version of Ecart?
Randy
That is the latest version, but your cart was likely created with an older version (or you haven't reinstalled lately). I'd reinstall the latest version, then open your cart object and click OK to regenerate the code. Then upload the WA_eCart folder to the site and that should resolve these warning messages.
RMor41509037
Hi Ray
I have reinstalled but am still receiving warnings
The PP_ECO_PHP.php file is still same date stamp as it was before is it not getting updated with the reinstall?
These are the warnings
[09-Feb-2020 18:37:23 UTC] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WAPPECOPFProHTTPObject has a deprecated constructor in /home/raceprotim/public_html/WA_eCart/PP_ECO_Scripts/PP_ECO_PHP.php on line 1079
[09-Feb-2020 18:37:23 UTC] PHP Warning: number_format() expects parameter 1 to be float, string given in /home/raceprotim/public_html/WA_eCart/PP_ECO_Scripts/PP_ECO_PHP.php on line 74
[09-Feb-2020 18:38:12 UTC] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WAPPECOPFProHTTPObject has a deprecated constructor in /home/raceprotim/public_html/WA_eCart/PP_ECO_Scripts/PP_ECO_PHP.php on line 1079
Thank you
Randy
That file will update if you re-apply any of the paypal express checkout server behaviors. You can find them on the pp_confirm.php page. I've attached the newest version if you want to just overwrite it manually.
RMor41509037
Thank you Ray
That did the trick!
jspoerer286380
Problem when updating from PhP 5.6 to PhP 7.1
Hello Ray... I had to update PhP version from 5.6 to 7.1 Everything was looking fine in my local development machine but when I uploaded my site to the "live" server the eCart session variables are lost when redirecting to eCart page.!! i.e. When I press any Add to Cart button... it redirect me to an empty cart page.
If I roll back to PhP vs 5.6 everything works as it should... I´m using eCart version 6.1.3
Any idea?
Thanks,
Jorge from Chile
Usually this would imply an issue with your php.ini file and the session_save_path setting pointing to a non-existent directory or a directory with incorrect permissions. Check that setting for both php.ini files for inconsistencies.
