MySqli update value with itself + new
Thread begun 11/19/2019 10:25 am by paulshoe379536 | Last modified 11/20/2019 2:06 pm by Ray Borduin | 1832 views | 5 replies |
paulshoe379536
I'm building a new table using values in "orders" table. The code seems to be working properly by selecting the correct section to process but I am not getting "customer_orders.OrderTotals" to update with it's current value plus the additional value from "orders.OrderSubTotal" when a "customer_orders" already exists.
My code below:
<?php require_once('../Connections/belles.php'); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
<?php require_once('../webassist/mysqli/queryobj.php'); ?>
$OnlineOrders = new WA_MySQLi_RS("OnlineOrders",$belles,0);
$OnlineOrders->setQuery("SELECT orders.OrderID, orders.OrderSubTotal, orders.OrderBuyerFirstName, orders.OrderBuyerLastName, orders.OrderEmail FROM orders");
$OnlineOrders->execute();
$wa_startindex = 0;
while(!$OnlineOrders->atEnd()) {
$wa_startindex = $OnlineOrders->Index;
$customers1 = new WA_MySQLi_RS("customers1",$belles,1);
$customers1->setQuery("SELECT customer_orders.Email, customer_orders.OrderTotals FROM customer_orders WHERE customer_orders.Email = ?");
$customers1->bindParam("s", "".($OnlineOrders->getColumnVal("OrderEmail")) ."", "-1"); //WAQB_Param1
$customers1->execute();
if ($customers1->TotalRows > 0) {
$ExecuteQuery = new WA_MySQLi_Query($belles);
$ExecuteQuery->Statement = "UPDATE customer_orders SET customer_orders.OrderTotals = customer_orders.OrderTotals + $OnlineOrders->getColumnVal('OrderSubTotal') WHERE customer_orders.Email = $OnlineOrders->getColumnVal('OrderEmail')";
$ExecuteQuery->execute();
$ExecuteGoTo = "";
if (function_exists("rel2abs")) $ExecuteGoTo = $ExecuteGoTo?rel2abs($ExecuteGoTo,dirname(__FILE__)):"";
$ExecuteQuery->redirect($ExecuteGoTo);
echo ('This is an updated entry >>> ');
echo ('Order Index: '.$OnlineOrders->Index.' - '.$OnlineOrders->getColumnVal("OrderEmail").' - '.$OnlineOrders->getColumnVal("OrderBuyerLastName").' - '.$OnlineOrders->getColumnVal("OrderBuyerFirstName").' - '.$OnlineOrders->getColumnVal("OrderSubTotal")).'<br>';
if ($customers1->TotalRows == 0) {
$InsertQuery = new WA_MySQLi_Query($belles);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "customer_orders";
$InsertQuery->bindColumn("OrderTotals", "d", "".($OnlineOrders->getColumnVal("OrderSubTotal")) ."", "WA_DEFAULT");
$InsertQuery->bindColumn("FirstName", "s", "".($OnlineOrders->getColumnVal("OrderBuyerFirstName")) ."", "WA_DEFAULT");
$InsertQuery->bindColumn("LastName", "s", "".($OnlineOrders->getColumnVal("OrderBuyerLastName")) ."", "WA_DEFAULT");
$InsertQuery->bindColumn("Email", "s", "".($OnlineOrders->getColumnVal("OrderEmail")) ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = "";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
echo ('This is a new entry >>> ');
$OnlineOrders->moveNext();
$OnlineOrders->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
I would try changing:
$ExecuteQuery->Statement = "UPDATE customer_orders SET customer_orders.OrderTotals = customer_orders.OrderTotals + " . $OnlineOrders->getColumnVal('OrderSubTotal')  ." WHERE customer_orders.Email = '". $OnlineOrders->getColumnVal('OrderEmail')  ."'";
paulshoe379536
I believe I did try it that way also but I will try it with a copy and paste of your code. Thank you.
That seems to have done the trick. I'll do some more testing and take a look at my previous code to see what I did differently.
Thanks again!
I think it was the missing single quotes around the email address.
paulshoe379536
The code you gave me has been working. However, when I attempt to open it in Dreamweaver's server behaviors I get an error message (attached JPG). If I save the code using the "OK" button in the dialog box it changes the code and the error message will not reoccur but the update quits working. I have added the update statements the first is the code you sent me (which is working), the second is the Dreamweaver updated code.
$ExecuteQuery->Statement = "UPDATE customer_orders SET customer_orders.OrderTotals = customer_orders.OrderTotals + \" . $OnlineOrders->getColumnVal('OrderSubTotal') .\" WHERE customer_orders.Email = '". $OnlineOrders->getColumnVal('OrderEmail') ."'";
Here are my questions:
Why am I getting this error message and why does Dreamweaver give me a version that fails? Is this an issue of the sequence of single and double quotes?
Also, I need to add another SET to the update. I need to SET customer_orders.LastOrderDate = $OnlineOrders->getColumnVal('OrderDate') and I haven't been able to get the syntax right to add that into your code.
paulshoe379536
I've solved the syntax problem with the LastOrderDate and have that working and miraculously that also eliminated the Dreamweaver error message. New update statement:
$ExecuteQuery->Statement = "UPDATE customer_orders SET customer_orders.LastOrderDate = '".$OnlineOrders->getColumnVal("OrderDate") ."',customer_orders.OrderTotals = customer_orders.OrderTotals + " . $OnlineOrders->getColumnVal('OrderSubTotal') ." WHERE customer_orders.Email = '". $OnlineOrders->getColumnVal('OrderEmail') ."'";
