PHP dynamic forms won't work on localhost but do on remote server
Thread begun 11/17/2019 7:49 pm by randyrie405335 | Last modified 11/19/2019 8:20 am by Ray Borduin | 785 views | 1 replies |
randyrie405335
I have several PHP forms that work perfectly on my remote host server but will not work on localhost. The MySQL server is operational on localhost so I'm at a loss as to why the forms work remotely but not locally. Any suggestions where/what/how I should look to solve this? I am attaching one of the forms (incl_admin_form_edit.php) for your review.
UPDATE
Thanks for your very prompt response. I found the issue to be the client typo'd his last name and the record was not being found when searched for. After correcting the spelling, the form worked. So this has been resolved.
If it works on one server and not on another, then it probably isn't an issue with the code, so I won't be able to spot anything.
It could be that your connection information is different on your server and isn't correct for the other. I'd start by adding this to the top of the page:
ini_set
("display_errors",1);
That might give you an error to go on at least and help you figure out what needs to be changed.
