Delete table record not maintaining associated linked MRT entries
Thread begun 10/05/2019 12:44 am by software.current355386 | Last modified 10/06/2019 3:02 pm by Ray Borduin | 734 views | 1 replies |
When deleting a database entry if it is linked to a MRT table then I would assume that if there are 6 linked entries then these would all be deleted also but that's not happening
tried deleting for detail and results page with same results
If you want to delete from both tables, then your page needs 2 Delete Record server behaviors applied... one for each table. Just make sure you don't redirect after the first delete so the second can run. You can probably copy/paste the code from the first delete and then just update the table and lookup column in and remove the redirect from the one that appears first.
