File Upload not saving file name to database, but saving other fields
Thread begun 9/30/2019 10:09 am by Nathon Jones Web Design | Last modified 9/30/2019 1:01 pm by Ray Borduin | 2316 views | 7 replies |
Any idea why this isn't saving the file name to database, but is saving the other data?
The form...
<form name="FORMupload" method="POST" action="">
<div class="form-group">
<label for="SMCuploadFILE">Please select a file:</label>
<input type="file" class="form-control-file" id="SMCuploadFILE" name="SMCuploadFILE">
</div>
<button type="submit" class="btn btn-primary mb-2" name="BTNupload">Upload File</button>
<input type="hidden" value="<?php echo $_SESSION['NEWformID']; ?>" name="HIDEformSTEP5ID">
<input type="hidden" value="<?php echo $_SESSION['NEWuserID']; ?>" name="HIDEformUSERID">
</form>
The server behaviours...
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "uploads/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["BTNupload"]) || isset($_POST["BTNupload_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "SMCuploadFILE", "2", "[NewFileName]_[Increment]", "false", $WA_UploadResult1_Params);
if (isset($_POST["BTNupload"]) || isset($_POST["BTNupload_x"])) {
$InsertQuery = new WA_MySQLi_Query($csdbmysqli);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "SMCuploads";
$InsertQuery->bindColumn("SMCformID", "i", "".((isset($_POST["HIDEformSTEP5ID"]))?$_POST["HIDEformSTEP5ID"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserID", "i", "".((isset($_POST["HIDEformUSERID"]))?$_POST["HIDEformUSERID"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuploadFILE", "s", "".$WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverFileName"] ."", "WA_DEFAULT");
$InsertQuery->saveInSession("NEWuploadID");
$InsertQuery->execute();
$InsertGoTo = "health-screening-form.php?tab5=1";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
Thank you.
NJ
Just to add that I've also tried...
$InsertQuery->bindColumn("SMCuploadFILE", "s", "".$WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverSimpleFileName"]  ."", "WA_DEFAULT");
...without success.
NJ
Your <form> tag needs to have enctype="multipart/form-data"
It has been an incredibly long....year.
Thank you Ray.
NJ
Is it possible to restrict the file types that can be uploaded?
You can use form validation to validate the file extension.
When I get to "Choose Variable to Validate" it lists...
SMCuploadFILE (which is the form field title and DB field)
SMCuploadFILE Field Name
SMCuploadFILE Temp Path
etc.
I also note:
SMCuploadFILE Extension
Shuold I be opting for one of those or just the SMCuploadFILE field name?
Thank you.
NJ
You can just use the field from the Form directly... the $_POST value. And use file extension validation.
