Search options working properly
Thread begun 8/15/2019 12:10 pm by EmmaMorris | Last modified 8/19/2019 9:01 am by Ray Borduin | 2818 views | 8 replies |
EmmaMorris
Hi.
I am having an issue with the medical database site that you have helped me with in the past, multiple times. I do not know if this is new or if I just missed it.
The search page is at 4patientsafety.org/mdb/search.php
What we noticed is that when I select a Gender from the menu and another multi-option drop down it is searching 'OR' instead of 'AND'
It seems to be fine and select the correct gender if I select it and one of the items that is NOT a multiple choice array
So if you search Female from the gender dropdown and then say OBGYN from the Specialties menu it brings up all OBGYN doctors not just female.
I will attach the page privately.
Thanks.
Emma
I'll need FTP access and a url to reproduce this issue in order to debug it and find a solution.
EmmaMorris
Here you go
I updated to the latest version of rsobj.php on your site and that seems to have fixed the problem.
EmmaMorris
Thank you.
Yes. I think I added the improvement I made for your search into the live product and probably made additional improvements to it. I think the latest version should work well for you.
EmmaMorris
Just found a problem that worked fine before
OK I think I have that one fixed. Let me know if you run into anything else.
EmmaMorris
Thanks so much Ray
