Update value with toggle button type checkbox using POST method
Thread begun 7/16/2019 3:18 pm by Jose | Last modified 7/18/2019 2:40 pm by Ray Borduin | 1787 views | 5 replies |
Jose
Hi there, I would like to implement an easy way to change status on a column type BOOLEAN in my database. So the idea is to use a toggle button to update value from 0 to 1 or vice versa . When I click the button on, I want to update it to "1" and when I click the button off I want to set it to "0" using MYSQLI update query. I'm currently working with an input type checkbox with the attribute onClick="this.form.submit()" but when I chick the button I only able to set it to 1 but when I click it to off does not change. So, if is possible to done it with just mysqli and the button, can you please give me some idea ? I'm going to attach the button and my query so you can see what I have donde.
Add a hidden form for the updated field value. You are using the checkbox and it won't have a value if it isn't checked. If you use a hidden form element instead it should work properly.
Jose
Thank you for your answer. I will try that.
Jose
Did you mean to add another form or just add a hidden field with the value ?
Just add a hidden form element with the record ID (what your checkbox value is currently) and give it a different name. Then update line 18 from:
$UpdateQuery->addFilter("herencia_id", "=", "i", "".($_POST['verification']) ."");
$UpdateQuery->addFilter("herencia_id", "=", "i", "".($_POST['hiddenName']) ."");
Jose
Ok thank you so much I appreciate it.
