powerstore Admin
Thread begun 9/16/2009 4:11 pm by tolushayoo193471 | Last modified 9/18/2009 4:24 pm by Jimmy Wu | 4593 views | 7 replies |
tolushayoo193471
powerstore Admin
Please I tried to do some product insert through the powerstore Admin, but it's not showing me everything on the page, and it's not allowing me to scroll down to press the button. I've attached a print screen.
thanks
Jimmy Wu
It looks like you made some changes to the css or applied some styling to the default pages? This may be what is causing the scrolling issue. Try reverting the styling you made to these pages and see if you can get the page to scroll.
tolushayoo193471
powerstore Admin
Thanks you are right, it now works fine. The problem am having now is the user end, after inserting product from the Admin area if put product option like colours, e.g. if i have red, blue, black. On the main page under the products, there will be a repetition of that same products 3times, but if i dont put colour option the product desplay will be fine. Please what am I doing wrong? Here is the link to the site
thanks
Jimmy Wu
It looks like something is causing the query on that page to be wrong and not filter based on the product options. Also the pagination is off, it says "Products 1 to 0 of 7 " which is wrong. The best way to get this working is to revert back to the original page again and make your styling changes on that, rather than trying to figure out what is causing the error.
tolushayoo193471
powerstore Admin
Thank you, on that page, the original page was Products_Results.php, I now resaved it as toys i edited the record set to filter
SELECT *
FROM products
WHERE ProductCategoryID = 9
the ProductCategoryID = 9, is for toys
the ProductCategoryID = 5, is for households good
the ProductCategoryID = 6, is for toys electronics
I have 3 product categories, if i revert it to the original page, I dont know how I will be able to do it. Please advice.
thanks
Jimmy Wu
The reason you are getting the three products on the page for the different options is because there is a product inserted for each of the different options into the products table. If you take the original SQL query from the product_Results page and add an additional condition that ProductCategoryID = 9 this should get the correct values.
tolushayoo193471
powerstore Admin
Thank you, it now works
Jimmy Wu
Glad to hear that you were able to get it to work. If you have any additional issues, feel free to open a new thread.
