No mail receiving
Thread begun 9/16/2009 1:38 am by ftg.peters379769 | Last modified 9/21/2009 11:32 am by ftg.peters379769 | 5881 views | 6 replies |
ftg.peters379769
No mail receiving
I've set up a form with CSS Form Builder. All the validations works fine. Then I've used Universal Email to get the form send to our company's email address after the submit ("send") button was pressed. The page goes to my confirmation page but I receive no email. What am I doing wrong ? I hope there is somebody to help me with this.
In the universal Email server behavior, you have bound the From Email Address to the "Contactformulier_group_Email" in the Validated Entries Collection. Instead of using the validated Entries binding group, use the Form Binding group.
ftg.peters379769
Still no mail receiving
I'v tried the solution you sugested but it still want work (or I did something wrong again). When I press the submit button I get the conformation php page but no I'm not receiving any email. Please someone help me with this. Thanks in advance!
You currently dont have anything in the email body, it is blank.
See the "Creating an HTML email" tutorial in the Solution Recipe section of the Universal Email support page:
universal-email/
One thing that can cause the email not to be sent is setting the from Display name. try leaving that blank.
If the email is still not coming through, check with your host to see if they can look into the SMTP server error logs and determine why the email is not being relayed.
ftg.peters379769
I tried your solution, but I can't get it working. There is nothing wrong with our host mail server neither, because I can sent mail with the sample php file attached. But that's not what I want: I want it to work with Universal Email! Thanks in advance for a reply with a solution.
For the From Address, you are using the Validated entries Dynamic Binding, use the Form Collection on the bindings panel instead of the validated entries bindings. These bindings only get a value if validation fails.
ftg.peters379769
No mail receiving - solved
I got it working by my self.
After a lot of trial and error I just left the SMTP server field empty
and now it's working finally !
Thanks for your help en efforts!
