Data Assist Can NOT access MySQLi Database
Thread begun 6/04/2019 5:04 pm by Carlos Quintero | Last modified 6/05/2019 7:42 am by Ray Borduin | 569 views | 1 replies |
Carlos Quintero
I am not sure if this is a Web Assist Data Assist issue or if it is Dreamweaver. I am on a iMacPro with the latest version and am running Dreamweaver current version CC which I believe is 2019. I had to unlstinall due to a number of errors that started to pop up after I upgraded dreamweaver. My issue now is that I am no longer able to make a connection with the MySQL database I see the WA Database panel, and the database connections but when I try to expand the database I get a No Tables Found. Please check your connection and testing server error. I am running the current version of MAMP also and I am able to access phpMyAdmin but for some reason I can't edit my existing WA files because the database connection is broken. I tried calling Adobe and they blamed it on WA. I searched the web to see if it was a MAMP issue and can't seem to find the problem. I don't expect free help so if you can provide me with whatever it is that I need to move this project forward, I would appreciate it and be happy to pay for your services.
IT is usually an issue with the testing server settings. I'd have to see those to potentially diagnose the issue. If you want to call me I can do screen sharing with you and debug it that way.
