adjusting inventory
Thread begun 5/29/2019 3:21 pm by paulshoe379536 | Last modified 5/31/2019 11:31 am by Ray Borduin | 1064 views | 2 replies |
paulshoe379536
adjusting inventory
What do I need to do to subtract the eCart quantity from "ProductQtyStock" in this product update?
(I corrected the original post; I had the "while" statement in the wrong position)
if ($_SESSION['eCartReceiptCompleted'] != true) {
$eCart1->MoveFirst();
while (!$eCart1->EOF()) {
$UpdateQuery = new WA_MySQLi_Query($auntbelles);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "products";
$UpdateQuery->bindColumn("ProductQtyStock", "d", "".$eCart1->DisplayInfo("Quantity") ."", "WA_DEFAULT");
$UpdateQuery->addFilter("ProductID", "=", "i", "".$eCart1->DisplayInfo("ID") ."");
$UpdateQuery->execute();
$eCart1->MoveNext();
$UpdateGoTo = "";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
I think the easiest option would be to use the Server Behavior:
Webassist->MySQLi->Data Management->MySQLi Execute Query
Then you could use a query like:
UPDATE products SET ProductQtyStock = ProductQtyStock - param1 WHERE ProductID = param2
Bind the two params to the eCart columns and cut and paste the resulting code into your while loop.
paulshoe379536
Thanks again Ray... got 'er done...
