eCart error on confirm page phpmailer.php
Thread begun 5/14/2019 1:40 pm by lr_leal239405 | Last modified 1/20/2020 10:43 am by Ray Borduin | 6313 views | 31 replies |
lr_leal239405
running eCart. (not sure what version it is... I updated in 2014). I got a couple of error messages from the code generated but was able to resolve one. I get
Parse error: syntax error, unexpected end of file, expecting ')' in /home/jvdydf5kad9w/public_html/webassist/email/phpmailer/src/PHPMailer.php on line 3382.
The code I see in that section is:
// If a MIME type is not specified, try to work it out from the name
if ('' == $type and !empty($name)) {
$type = static::filenameToType($name);
// Append to $attachment array
$this->attachment[] = array(
0 => $string,
1 => $name,
2 => $name,
3 => $encoding,
4 => $type,
5 => true, // isStringAttachment
6 => $disposition,
7 => $cid,
return true;
The line is this one : 3 => $encoding,
(Also, not sure if you fixed it later, but the error I got earlier was on confirm.php / eCart1_PHP.php was missing quotes on (I think this line $WA_columnTypesStr = "@@ColumnTypeStrParam@@";).
Another was that... even though I told it to use a Paypal Sandobx and entered credentials, it still had the 'Use Sandbox' as 'False' and my credentials didn't make it into the generated code.
Maybe you've fixed those glitches by now but just in case, wanted to let you know.
However I still have the error at top.
I feel like the PHPMailer.php didn't get uploaded properly. Can I get FTP access and a URL to reproduce? The error and code don't match up, so something strange is going on.
lr_leal239405
I can't give ftp to the full domain but to the folder. I copied the Webassist and the WaEcart folders in there.
Try the below.
I'd have to have access to a folder with files to reproduce the issue in order to debug it. What version of the WA_Email.php file do you have? Did you try re-uploading it? Access to a different folder with a copy of those files doesn't help me with debugging an issue.
lr_leal239405
That is the folder...the Actual folder with the entire shopping cart. The index.php file being the page:
How can I reproduce the error using these files? When I browse to: https://www.yourdomain.com/eCart/ I get a completely different error.
I went through all of your pages and updated the paths so they pointed to the correct folder.
Then I went through the checkout, but I changed the trigger so the email is sent before the purchase is made.
I got the email and didn't see the error you reported.
I did have to update:
$Email->BodyFile = "webassist/email/templates/wa_receipt3.php";
$Email->BodyFile = "webassist/email/templates/wa_receipt.php";
Since wa_receipt3.php wasn't uploaded to that folder.
lr_leal239405
I'm getting different errors now. I see it's generating code that uses mysql instead of mysqli ?
Warning: mysqli_select_db() expects parameter 1 to be mysqli, string given in /home/jvdydf5kad9w/public_html/eCart/confirm.php on line 324
Notice: Undefined offset: 1 in /home/jvdydf5kad9w/public_html/WA_eCart/WA_eCart_Database_PHP.php on line 20
Notice: Undefined offset: 2 in /home/jvdydf5kad9w/public_html/WA_eCart/WA_eCart_Database_PHP.php on line 21
Warning: mysql_query() expects parameter 2 to be resource, object given in /home/jvdydf5kad9w/public_html/eCart/confirm.php on line 358
You will need to attach a copy of the pages with the errors. It looks like the FTP information you provided earlier won't let me access them.
lr_leal239405
ok. I reverted back to what I had before you had access (cause it got a bit messy when I tried to fix the rest of the errors). I have the same errors mentioned above on the confirm.php page.
I had another one error I got thru that said:
"mysql_select_db() expects parameter 2 to be resource, object given"
I found it's because it's trying to use mysql while my connection file is mysqli. I ran the whole page thru an online converter from mysql to mysqli (object oriented) (it changed line 358 and other references to mysql_) and it got rid of that message on the confirm.php page.
On first test it gave me the checkout_failure.php page that says 'Transaction could not be completed'. On 2nd try (without changing anything), I got the errors above again.
(Also, last night I remembered that it didn't auto create the databases so I downloaded the sql file from your site in order to create the 'orders' and 'orderdetails' pages which I had to rename to 'ecart_orders' and 'ecart_orderdetails' because we already had one that is being used named 'orders'. There's also an existing 'products' page so I have one going called 'eCart_products'. I was wondering why it didn't create them in the first place even though I know I had selected the right option in the checkout wizard process. But this is a side note.
For now I just need it to complete the order with my Paypal credentials (posted below).
These are the errors on the confirm.php page currently:
Notice: Undefined variable: mysqli in /home/jvdydf5kad9w/public_html/eCart/confirm.php on line 358
Notice: Trying to get property of non-object in /home/jvdydf5kad9w/public_html/eCart/confirm.php on line 358
(Oh, and that webassist email template you mentioned is in there).
