When I apply a MySQLi Manage Relational Table behavior, it is somehow applying an old function
Thread begun 4/17/2019 12:29 pm by TroyD | Last modified 6/07/2019 6:57 pm by Ray Borduin | 8120 views | 43 replies |
TroyD
I have an old insert page that I needed to convert to MySQLi. It includes a single insert behavior and a manager relational table behavior. I stripped out all the old behaviors and js so that I could apply them as new MySQLi behaviors.
The form contains a multi select list named “ProductCategory”, populated by a rs. The list is used for the options form field in the MRT.
When I applied the MySQLi MRT behavior, it modified the select list as it has in the past by adding the [] to the select name
<select name=“ProductCategory[]" multiple="multiple" id=“ProductCategory”>
It also modified the option in the list to look like this…
<option value="<?php echo($rsRecordSet->getColumnVal("CategoryID")); ?>" <?php if (!(strcmp(($rsRecordSet->getColumnVal("CategoryID")), WA_AB_returnPreSelectValue($WA_PreSelect_RelationalTable_1, ($rsRecordSet->getColumnVal("CategoryID")))))) {echo "selected=\"selected\"";} ?> ><?php echo($rsRecordSet->getColumnVal("CategoryName")); ?></option>
This is now causing a fatal error in the list box, which is understandable because I’m pretty sure that the WA_AB_returnPreSelectValue() function is an old one and isn’t used anymore.
Fatal error: Call to undefined function WA_AB_returnPreSelectValue()…
I’m not sure why or how it keeps being applied when I use the Webassist > MySQLi > Data Management > MySQLi MRT behavior.
Any thoughts?
I am using the latest download of DB 2.3.5, which I installed yesterday. I deleted the files rsobj.php and queryobj.php and regenerated them. Not sure what I’m doing wrong. Do I need to do something different to the multi select list before I apply the MRT? It’s been a while since I applied a MRT from scratch.
Thanks,
TroyD
This is just leftover code that needs to be updated...
this:
should now be:
<?php echo(in_array($rsRecordSet->getColumnVal('CategoryID'),$RelationalQuery_1->getSelected())?"selected":""); ?>
TroyD
That's what I thought but it keeps adding it back in there when I open and make changes to the MRT behavior. I'm now getting Truncated incorrect INTEGER value: in my list and when I look at the source generated it shows this...
<option value="1" select="" parent_categoryid="" from="" category_products="" where="" parent_productid="0" and="">Truncated incorrect INTEGER value: </option>
. That looks like I have something else breaking my code maybe but I am still looking. I will double check all my syntax.
TroyD
The code must think your MRT is mySQL and not MySQLi for some reason. It will use the old syntax with the MySQL version. I'd need FTP access and a URL to reproduce to debug it, but it sounds like the MRT server behavior may not be updated properly to MySQLi yet on the page or maybe your connection isn't being recognized as MySQLi.
TroyD
Ray,
This is currently on a local server. Would it help if I attached the page file?
I have several recordsets and the single insert behavior that all use MySQLi. I've removed the old connection as well.
The only original files I still have included are ckeditor/ckeditor.php, file_manipulation/helperphp.php and security_assist/helper_php.php. I've removed all the other old files.
It might help. I can take a look.
TroyD
Ray,
See attachment. I simplified this page as much as I could, hoping I would either see, or at least strip out any issues but it continues to elude me. If I open the MRT wizard and click through to "Finish", it adds the old code back to the multi-select box. In the attached file, I have that part removed completely and it still won't work. No matter what I do, it will not write to the relational table in my db. It inserts the main product into the product table but nothing for the relational selected options.
I am sure I am overlooking something here but I don't know what it is.
Thanks for any help you can provide me.
TroyD
With MySQLi on an Insert page, you don't have to use MRT at all. In fact, with a multi-select list like you have, you don't even need to use Multiple Insert server behavior.
You can just use the Insert server behavior and bind the DepartmentCategory array to the field you want repeated and the server behavior will do the multiple insert automatically.
TroyD
Ok, I wondered about that but assumed that I would at least need to use the multi-insert behavior. I did as you mentioned and it works perfectly using just the single insert behavior.
For anyone else looking for this solution, I added a second Single Insert behavior to insert into a table that acts as the relationship between the department categories table and the products table. I have 3 tables here.
tblProducts (first insert adds the new product to this table)
tblDepartmentCategories (this table holds the department categories and is used populate the multi-select list)
relDepartment_Products (second insert adds all of the selected department's ids and the product id into this table)
In the second insert, I bound the product id column to the session created by the first insert behavior. I then bound the department id’s column to the multi-select. I assume you would have to manually add [] to the name of the multi-select like this, name="DepartmentCategory[]".
If I have anything wrong here, please let me know.
So, having that one finished, I am now working on the update page for this same record. I’m not sure yet if I will see the same issues since I will need to use the MRT behavior, but I will report back.
TroyD
TroyD
I'm having the exact same issues with the update page with regards to the old code being inserted. But this time, it's inserting the old code within the part I added from your post up top.
Here is the select with your added "select if" code. It works to select the matching ids already in the relational table, but if I click Update, I loose them. All the relational ids are removed from the table. This might be a different issue, I'm still investigating that.
<select name="u_DepartmentCategory[]" multiple="multiple" id="u_DepartmentCategory">
while(!$rsDepartmentCategories->atEnd()) { //dyn select
  <option value="<?php echo($rsDepartmentCategories->getColumnVal("DepartmentCategoryID")); ?>"<?php echo(in_array($rsDepartmentCategories->getColumnVal('DepartmentCategoryID'),$RelationalQuery_1->getSelected())?"selected":""); ?>><?php echo($rsDepartmentCategories->getColumnVal("DepartmentCategoryName")); ?></option>
->moveNext();
//dyn select
$rsDepartmentCategories->moveFirst();
</select>
If I open the MRT wizard and inspect or change it, and click "Finish", this is what happens to the multi-select. You can see that not only is old code inserted, but it splits out the current if statement.
  <option value="<?php echo($rsDepartmentCategories->getColumnVal("DepartmentCategoryID")); ?>"<?php echo(in_array($rsDepartmentCategories->getColumnVal('DepartmentCategoryID'),$RelationalQuery_1- <?php if (!(strcmp(($rsDepartmentCategories->getColumnVal("DepartmentCategoryID")), WA_AB_returnPreSelectValue($WA_PreSelect_RelationalTable_1, ($rsDepartmentCategories->getColumnVal("DepartmentCategoryID")))))) {echo "selected=\"selected\"";} ?> >testgetSelected())?"selected":""); ?>><?php echo($rsDepartmentCategories->getColumnVal("DepartmentCategoryName")); ?></option>
->moveNext();
//dyn select
</select>
I don't have any redirects in either of the Update behavior or the MRT behavior, so I know it's not moving away form the page.
Is there a different way I should be doing this page as well?
Thanks,
TroyD
